I sure would love to talk to the tesla engineers on this. My guess is they may have not put this through much testing, since
my guess is I might be the first person trying this is the real world residential, but I could be wrong.
There example does not touch on technically, should it act as I am expecting, or is the gen 3 just dumb logic with no
communications between the units. Even with I turned on the other 2 units, it still forced them to max 33 amps, even with only one plugged it.
This may be the only instance in my history of TMC where my experience worked and yours didn't hahaha.
As @jjrandorin indicated, I have two Gen 3 chargers each on their own 60A breakers with their own conductors. I did not daisy-chain them the way some folks on TMC seem to have them installed.
Each of the two is individually configured to be max 48A charging (all 5 green LEDs light up when I'm provisioning them). But the site is maxed at 64A. So when only one car is charging, it gets the max 48A. If two cars are plugged in and charging, then each is de-rated to 32A. When one car finishes charging (and is still plugged in), the other one slowly goes from 32A to 48A (over about 5 minutes).
So setting it up was kind of annoying. Aside from the wireboxes not being interchangeable (I don't are what people tell me, they simply don't swap hah)... setting them up as master/slave wasn't as easy as I thought.
The Master unit defaulted my site to 0A when the slave unit was wifi-connected to it. Which confused me since that broke both chargers haha. Also, the UI is absolutely rubbish. Once you have a slave unit set up, the stupid [Enable] bar on the master unit's wifi configuration has to be blue. They could have used the tried and true "on off" rectangle. But instead, Tesla went with a header label ... that especially if you're color-blind ... it'd be impossible to know you had to tap it.
Left Screenshot = Fail
Right Screenshot = Awesome
