Gen 3 Wall Connector current decrease? Anyone else seeing this?
I've had the wall connector connected (by an Electrician) to a 60Amp circuit for almost a year. It has supplied 48Amps of current to the car without fail until the last couple of months. It seems that, when I have the car charging with a Max setting of 48 Amps, the current drawn by the car is 41 Amps. If I decrease the current limit to 41 amps, the car only draws 38 amps. Seems to be linear down to 32 amps (ish) and then the max meets the current draw into the car.
Is anyone else experiencing this? I have a service request in for another issue (passenger seat issue) and added the comment to the communications to the service center but haven't received a response. Just wondering if this is a firmware issue, or something more concerning.
Thanks for any info. I searched around and didn't find this exact issue. I do see the issues with the max current being a multiple of 16 A, but this seems a bit odd when compared to those issues.
Bruce
jjrandorin
Moderator
Nov 28, 2018
16,752
22,142
Riverside Co. CA
I have seen some threads where people changing the amp settings in the app introduce some "wonkiness" to charging. The remedy I saw for that was to turn up the charging amps in the car if possible, and not change it in the app.
Have you tried turning it back up in the car and seeing if it sticks there?
Reactions: Rocky_H
I appreciate the help with this one! Unfortunately, I've tried that too. Tried making the change in the car has the same behavior as making the change in the app. I doubt it's the issue, but I think I'll change my Tesla credentials and hopefully deauth all the things I have connected. Maybe eliminate the possibility of a third part app doing something weird.
AlanSubie4Life
Efficiency Obsessed Member
Oct 22, 2018
14,284
18,424
San Diego
Might be related to that. Could be a soft failure of part of the PCS, who knows - signature may have changed with software updates. Charging equipment doesn’t seem that likely but certainly possible.
Check the voltage the car sees at each of the current settings (after it has ramped and warmed up) to give a bit more info here on whether there could be an issue with the wall connector/resistance. Certainly wouldn’t rule that out either without more info.
Don’t give up on hassling Tesla about it and report back what they find!
I'll go back and check the voltage to see if it sags at the higher current limits in a bit. I just did the whole password reset thing and will give it some testing shortly. I really appreciate all the input!!
Using the measurements below, it looks like the maximum resistance I would see is about 0.3 Ohms. Unless I'm missing something here, I don't think it's the wiring or connections. Please feel free to correct me if I'm wrong. The car is currently upgrading to 2022.16.2, so I'll check it again then.
Oh and the Tesla password change had no effect on the issue... Was worth a shot...
May be time to hit up Tesla service again :-/
Max Current LimitVoltageCurrent Draw
4823841
4723840
4623839
4523939
4423838
4323837
4223837
4123836
4023835
3923835
3823934
3723934
3624033
3524032
3424031
3324031
3224030
3124130
3024029
2924128
2824227
2724227
Reactions: AlanSubie4Life
For completeness sake, you should test at another EVSE, preferably one that has 48a capacity like at the service center. Just to narrow down between the car and the wall connector.
Good idea... I'll have to find a private one to borrow as, since I live in Alabama, it would require a trip to Georgia or Tennessee... But that's another soapbox of mine. :p
4823841
4723840
4623839
4523939
4423838
4323837
4223837
4123836
4023835
3923835
3823934
3723934
3624033
3524032
3424031
3324031
3224030
3124130
3024029
2924128
2824227
2724227
What was the voltage when it first started to ramp up? At my house I see about a 10V drop from no load to 48A; however, about 4V of that is a drop at the service panel. Not sure if this 4V drop on the power provider side is common or not?
According to the API (completely disconnected), it's 238.2v (currently). This is the normal average for my home. In addition, we have one of those Ting home power monitor things and it hasn't seen any dips in the power (within a standard band):
"config_status": 5,
"contactor_closed": false,
"currentA_a": 0.0,
"currentB_a": 0.0,
"currentC_a": 0.0,
"currentN_a": 0.0,
"current_alerts": [],
"evse_state": 1,
"grid_hz": 59.9,
"grid_v": 238.2,
"handle_temp_c": 23.7,
"input_thermopile_uv": -131,
"mcu_temp_c": 30.8,
"pcba_temp_c": 26.1,
"pilot_high_v": 12.0,
"pilot_low_v": 12.0,
"prox_v": 0.0,
"relay_coil_v": 12.0,
"session_energy_wh": 11321.2,
"session_s": 0,
"uptime_s": 128002,
"vehicle_connected": false,
"vehicle_current_a": 0.0,
"voltageA_v": 2.1,
"voltageB_v": 2.1,
"voltageC_v": 2.1
I may log the JSON for all of this for an entire charging session to check the temps as well... Hmmm
It looks like you're reading the current from a deeper source than the usual car screen or Tesla app. Perhaps you're reading the current going into the battery which may be different from the current going thru the charger as the car often uses some current for non-charging purposes. What does it say on the car's screen (or app)? Does it really say "238V 41/48A"?
Actually, the table above was from the car's screen data. I have (since then) written a groovy app to read the Json from the wall connector API and log the data into a database table to get the current/voltage measurements directly from the connector. It matches what I'm seeing in the car display.
According to wall connector support, they say it's the car's charger(s) that are at fault.
AlanSubie4Life
Oct 22, 2018
14,284
18,424
San Diego
Yes, if it were the wall connector, I would kind of expect it to limit the maximum current available (since that seems like it would be a good way to protect it if it were marginal in some way), but that is not what is happening here.
I guess we will see! Thanks for the updates!
