Joseph
Something to add.
I know it sounds odd that electric motors are more efficient at high rpms. My understanding is that at lower rpms, the current (amps) vs. voltage proportion is higher than it is at higher rpms. So basically, low rpms use more current but less voltage and higher rpms use less current but more voltage.
High current and low voltage is less efficient. I don't know why, but I know for certain that is true. A wire containing 100 amps at 50 volts will create much more heat that 100 volts at 50 amps.
Also, there's nothing wrong with transmissions. They improve performance a whole lot, but the problem is reliability. Super high rpm and super high torque puts too much stress on the transmission. Plus, it's a disaster on the clutch because the "engine" can't wind down quick enough. A gas car will lower rpms in an instant, allowing for a smoother shift; but an EV spinning at 14k rpm will still be spinning very quickly when you shift it.
