Jeda should technically work just as well as any other pad on the market for iPhone X at 7.5V. That’s why I was confused with the previous comments.
After a firmware update, a couple months ago, the front USB ports got a bump in power. According to this video, they are now capable of putting out 2.6 amps. At 5 volts, that’s a total of 13 watts. Plenty for iPhone fast qi charging (which maxes out at 7.5 watts).The issue isn't with Jeda, it's with the front USB ports, which only output 5W each.
One solution is to put a battery "buffer" in between the USB ports and the charging pad, which is what the Jeda FC kit is and is also what is built-in to the competing Nomad product (Wireless Charger)
The other solution is to run two cables from a suitable dual USB charger plugged into the 12V socket under the center arm rest.
Yes, shouldn’t be required for iPhones. Only phones that can take advantage of higher wattages would benefit.Not disputing this, but if this is true, is there any point in the fast-charge kit from Jeda, the battery in the Nomad, or running two cables to a charger plugged into the 12V socket? Are these now redundant? Or perhaps they are required for Android fast wireless charging (but not iPhone 7.5W)?
Does anyone 3D print a thicker bottom bar (that snap in cable cover) seems like it would be a good thing to have another 3/8" height on that as the thicker pad of the charger leaves very little ledge left to hold the phone in, would be better to close the gap between that bar and the storage lid anyway as we have dropped the phone in the storage through there many times as it is.View attachment 315821
Recently saw this, suspect it would help.
Ordering one now too.
Thats the only thing i didnt like about the Jeda.
Got my skyline extender ledge piece. Works great with the Jeda.
