Grinding in front wheels after tire change
Discussion in 'Model X' started by Xtrordinary, Jun 27, 2017.
  1. Xtrordinary
    Xtrordinary New Member
    Calgary
    I am posting this to save others time in case they make the same stupid mistake I made.
    I've got summer and winter tires mounted on two sets of wheels and I swap them out each season. Been doing this on all my cars forever. Swapped the winters off my Model X and put the summers back on, and then noticed a grinding sound on both fronts, especially when turning and reversing.
    Normally wheel grinding is a bent heat shield or rock in the rotors, but after checking them and pushing the heat shields out, the grinding was still there.
    After days of searching, I finally discovered what most of you probably already know:
    YOU DON'T ROTATE MODEL X TIRES. I had moved and crossed over the rears to the front, and of course the sizes are different from front to back, so, duh, they didn't fit right.
    Anyway, hope this helps somebody out there save some time.
    • Informative x 4
  2. araxara
    araxara S-P85#3,218 X-90D#3,299
    Tucson, AZ
    Well, at least you answered our question about if you can put larger tires on the front of a Model X.
  3. bushburner
    bushburner Member
    new orleans, la
    the more you know
  4. rjdoc74
    rjdoc74 Member
    LA, CA
    Thanks for posting.
  5. zackmilo
    zackmilo Matching X+3
    Los Angeles, CA
    Same thing happened to me. Shop didn't know.
  6. rlpvl
    rlpvl Member
    Shingle Springs, CA
    You do rotate Model X tires, but by swapping right with left, not front with rear.
  7. vandacca
    vandacca ReActive Member
    Hamilton
    Assuming that the wheels are not directional. If they are, you can't even rotate left-right. IIRC, the performance tires are directional.
