I noticed that the psi reading changes up or down about .4 pounds while it's sitting cold.
Also one of my sensors read the tire temperature 4-5 degress higher than the other 3. I swapped it to another wheel and same results.
Anyone had any of the above issues?
I also have one sensor that reads higher than the others for no particular reason.
I'm experiencing the same issue
Hi Andy,
You are a popular guy, your PM box is full.
re the Accutire...the in-car unit on the fobo lets you set an additional alarm point, along with the legal-required 25% one - I like to know when any tire has barely begun to drop, like 2 lbs, so I can get to it before it is a problem. Also the fobo+ lets you set high pressures, which the Tesla requires - if the accutire is made for normal car tires, you will be setting off the high pressure alarm on any warm day (don't see full specs for it, you can check). I'd just need to know more about these...
I received my set of Fobo sensors about a month ago, but just got around to putting them on today.
It seems that two of the four sensors are defective.
I am unable to get two of the sensors to pair with the in-car unit. The in-car unit acted like there wasn't any sensor at all. Now, I do have LTE on my phone, and I've since then read that it might be interfering with the bluetooth signal, so I should turn off LTE and try again. Or, as Andy suggests, I might try replacing batteries (although I have no clue how to open up the sensor without damaging it).
I'll make another attempt to get them paired later today.
