Thanks for the update.Once you have all the panels off and know where each bit goes it's pretty simple...no idea on how the reattaching panels goes...that's this afternoon's job!
Does anyone know if the Version F kit includes the DIY Harness? (to activate the front speakers).
Thinking of getting the DIY kit first and then saving up for the Version F kit but if version F includes the DIY then i’ll just hold off for now.
Also I have the Sept 2020 build so no rear parcel speakers so i’ll have to cut holes. Anyone had any experience with this? Is it easy enough to do?
many thanks
I thought exactly the same. It's not intrusive but defo louder.Indicators are definitely louder
My full system has been working for a year now without a problem. Which kit are you using and is your car from Freemont or China?My car giving out ecall need service error after installed the hansshow speakers activation kit. Uninstall the kit, the error message disappear immediately. Anyone having the same issue?
Been a long time since I did this (don't even have the car anymore)Through some speculative ebay bidding I've ended up with two wiring harnesses that activate the four unwired front speakers and two rear speakers. Car is MIA early 2020 so all speakers are in place.
One kit is branded from Basenor. The other has no branding. I appreciate this thread discusses the Hansshow kits but many of the installation steps will be the same.
After watching various videos and trying to determine the differences in harness between LHD and RHD I've got a few questions:
1. Is there a connection to the rear speakers on the near side in RHD cars, as well as on the off side? (if not, the annotation on the image is most likely wrong and/or both kits are for LHD cars)
2. Do I need a powered sub to activate the parcel shelf speakers?
3. Any reason why the positioning of the connector annotated by the blue line is so different between the two cables?
Grateful for any tips or confirmation as to which cable will work if either/neither.
Thanks for the response.Been a long time since I did this (don't even have the car anymore)
Question 1. No the connection to the rear is down the offside
2. No, the speakers work fine with the current system
3. Possibly because the control system/amp is behind the glovebox on rhd cars. I had the issue where they sent me the wrong cable first off so was trying to get a lhd cable in to a rhd car...that did not work...
