beachsideev
Well, I'm not sure what my problem is, if there is one.
I looked at the diy harness that connects between the ice and the factory wiring and the front door woofers do get passed through without going to the crossover box. I checked continuity for all of the orange wires (hansshows wire color for signals that are passed through) and nothing is crossed. That part appears to be wired correctly. I used this diagram to determine the speaker wiring at the ice connector:
Next I did some a/b testing with the extra speakers installed or removed by pausing a song in the middle and adding or removing the harness at the ice. If you don't plug the connectors in all the way you can still get conductivity but it doesn't latch so removing it is a lot easier.
The bass response sounded exactly the same to me with or without the harness installed. I tested the polarity again with the app and I got different results for the door woofers this time. Now both door woofers appear to have the correct polarity. One thing I did do differently this time when testing the polarity was i unplugged one of the connectors going into the crossover box to disable the door tweeters. I'm not sure why the door tweeter would be causing issues with the app, especially with an 80 hz pulse, but it seemed to give more consistent results with the door tweeters disabled.
I tested the rear shelf speaker I swapped yesterday and now that one is being detected as being backwards. Grrrrr. Again I was having trouble getting consistent results until I placed a towel on the back glass above the speaker to try to eliminate reflections off the glass. This seemed to make the results much more repeatable. Again I think the app might be too sensitive to reflections which cause erroneous results.
Anyway, I'm not sure what to do now. I have the harness hooked back up but I haven't reinstalled the panel to get at the wiring. I will probably undo the polarity swap I did to the right read shelf speaker. I also might try another app first.
What I am going to do now though is turn on the stereo and wax the car because that requires much less thought.![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
