I have noticed the supercharging speed to be the same or very similar in case they don't work, but the fans then run at max speed and it's very loud.
Are you saying there is no difference in speed/noise of the fans with louvers opened/closed?
Not sure, maybe when it is super hot outside and you hammer it hard, so the temp dissipation of all power components is very high, then maybe it opens either, who knows..so when there is enough "air" to cool the central radiator there is no need for AC to help cool it down
Yes, but only if the temp of the batt is approaching the active cooling target temp and the active cooling is needed. If the battery is cool, it is completely quiet, louvers stays closed.but when supercharing the air is not enough and AC kicks in at cools the radiator, therefore side louvers should open?
Yes, mine also was...it's normal when the outer louvers don't work... When they does, it's much better then..yes, yes, understood.
my car just sounds like a jet engine when SuCing![]()
Same here. Fans sound like a harrier jet taking off under these 3 scenarios on our old S85:yes, yes, understood.
THC_w0134_radRightShutrNoFeedbkRadiator error means central unit, not side louvers I believe? Whats your error exactly?
Thanks for the assist. I'll learn more about them; doesn't look very difficult to change.This is central radiator flap not working, see this page (use google translate)
E-Buddies Aktuell
Tesla Experten, Tesla Akku Reparatur, Tesla Diagnose, Tesla Remote Diagnose, Tesla HV repair, Tesla Battery repair, Tesla Wartung und Inspection.www.e-buddies.de
Hi, congrats on your success! I used to have also recircValve and RCCMact with activeAero faults, changed only the recirc valve for some from Ali and not immediately, but after some time all the faults had disappeared...I finally repaired my side louvers. Cars cooling works much better now.
Will write a how-to with pictures tomorrow.
I recently had 3 software updates in the last month and had to do a reset after my air suspension would freeze up on the height selection menu. Lo and behold, my right radiator no feedback alert went away after being present in Service Mode for several years.I found out doing a hard reset makes alert go away faster once the issue is fixed.
My point is that the NEW ONES have the same defect and Tesla Engineering knows it. You could go and buy a brand new one from Tesla and it will fail almost immediately. My car stayed at a service center for over a month with them trying to fix the issue. They put SIX different louvers on it and they all failed within 24 hrs. (Note that this is for the RIGHT Louver. The left one does not appear to have the same defect) The service manger contacted Tesla Engineering and after a long battle of back and forth... was told that this is a KNOWN ISSUE, but they also weren't going to (at that point) release a service bulletin. The Model S and X are notorious for failed A/C compressors and this louver failure is a direct contributor because the car cannot get the additional airflow that is needed on very hot days. If you have a Legacy Model S or X, and your A/C failed or sounds like a 747 during takeoff when you activate A/C while parked... then it is possible that you have this issue. Not only does the right louver not open, it communicates with the Left Louver so it may not open when needed either. My A/C failed 1 year before I realized that the louver was even an issue. This was 100% confirmed to me by the Service Manager and I believe that his or her frustration with the situation convinced him or her to give me for honesty than management would prefer, which is why I won't mention the person by name and label as him/her. The service manager refunded me completely even for the A/C repair and did give me a loaner during this month. The SM was awesome, but ultimately his or her hands were tied. I will GLADLY pay for a new louver part that actually functions correctly. My issues are that 1) Tesla won't even tell you what the Service Codes actually mean (I had the rightShutterNoFeedback code for years and everyone (plenty in these forums) either said it was a common/ghost code/don't worry about it... if you get these codes you need to worry about them because that means THINGS DON'T WORK CORRECTLY 2) the Service Center team had "a hell of a time" getting communications from Tesla Engineering, and 3) There is just no where to go within Tesla from the customer perspective.@wtshirley I understand your anger, but what would tesla do? These things just have some lifespan and after which they need to be changed. Its made of plastics that deforms - bear in mind the car can do several louver cycles per day if you drive it a lot and each time a little bit of plastic is damaged.
"our" fix makes it a cheaper repair, there is always an option to buy a new louver.
The sourced parts might be different based on your location, so hopefully you are in the clear. I know that there was a "G" version of the part that showed up in the part guide, but was quickly removed.Odd. I had both louvers error and managed to fix the right one with toolbox calibration and left one with a “toothpick”. Most likely right will fail soon, but at least I know how to fix it now.
