Heads up: Replace Key Fob Battery
Discussion in 'Model S: User Interface' started by Cosmacelf, Jul 2, 2015.
  1. Cosmacelf
    Cosmacelf Active Member
    San Diego
    So I recently got a warning on the dash that my key fob battery needed replacing. No problem, I have a bunch of 2032 batteries in the garage. I put a fresh one in, and check the car, warning message still there. Hmmm. Maybe that battery was old. Try another one. Same thing. Ok, maybe I need to drive it for a while to reset the system. Nope.
    Long story short, it turns out that it was the other fob hanging in the hallway that needed a new battery, not the fob I carry with me all the time. The "I need a new battery" message from the fob seems to travel pretty far...
  2. Chipper
    Chipper Active Member
    Chattanooga, TN
    I am surprised there is a message at all. I have had my P85 for 18 months and my battery went completely dead last summer. I got zero notifications. I wonder when they added this notification?? I LOVE the fact that our cars just keep getting better!
  3. scottm
    scottm Active Member
    Canada
    So is it better to store the fobs far away from the car, out of pinging range, to prolong battery life?
    Currently thats what Im doing. The spare is a couple of rooms away from the garage, not in the back hall next to the garage door where all the other keys hang.
  4. arg
    arg Supporting Member
    Cambridge, UK
    That's almost certainly why the battery needed replacing in the first place!
    The fobs work by the car continually transmitting on one frequency; the fobs are normally dozing in a low-power state but wake up when they hear the beacon from the car and then transmit a reply. So a fob that's within reach of the car's transmissions will use up the battery much faster than if they are dozing in a radio quiet zone.
    Also potentially an issue with the car failing to lock if you rely on walk-away locking and the car parked close to the house.
  5. jerry33
    Texas
    Yes. in other cars 5 metres is the recommended distance. I doubt it would be different in the Model S. (I don't recall any distance being specified in the manual, but I could have missed it.)
  6. manis
    manis Member
    Bay Area, CA
    Unless a significant other is going to use the spare might as well just take the battery out and put a rubber band around them or something. That's my plan once I pick up my car. Seems like the spare is going to die during the same period as the primary one, at least this way you might have a good battery handy if you don't have a battery laying around.
  7. jerry33
    Texas
    If it's not within pinging distance, in or out won't make a material difference in life.
  8. manis
    manis Member
    Bay Area, CA
    But it has to trickle enough power to ping or be pinged (not sure if it does the pinging or the car does)
  9. jerry33
    Texas
    The car does the pinging. In the Prius, which works similarly, the battery in the spare fob lasts for years (at least five). That's why I said "material difference".
  10. Cosmacelf
    San Diego
    The funny thing is that while my spare fob seemed to be close enough to occasionally tell the car that it is low on battery, it isn't close enough to allow the car doors to open. I had to be close the car with my other fob for the doors to open (I have auto lock).
  11. caddieo
    caddieo Member
    Palm Coast, FL
    Yes. Distance is important and there have been various posts as to how far. In addition, some RF shielding is advisable. I keep mine in metal containers in the foyer leading to the garage. It's easy for me to do as my fobs are used by themselves and not attached to key rings or whatever. I also recall some posts that recommended putting the fobs in the refrigerator. How's that for shielding? :wink:
  12. jerry33
    Texas
    Should be good as it's mostly surrounded by metal.
  13. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Didn't they replace the batteries in your key fobs at your annual service? That's on the list, but you have to remember to give them your spare key fob.
  14. jerry33
    Texas
    That's the hard part :)
  15. GaryREM
    GaryREM Member
    Fairfax, VA
    The SC gave me a spare battery for the other fob at my annual service.
  16. caddieo
    caddieo Member
    Palm Coast, FL
    I got one also.
  17. mikeg561
    mikeg561 Member
    huntington beach, ca
    I store my car keys kind of close to the car, so I wrapped my spare fob in aluminum foil. Before the foil I could lock/unlock the car from the key drawer area. After the aluminum foil, I could not lock/unlock. I am going to assume that means the car can no longer ping the fob.
    Mike
  18. rickgt
    rickgt Enthusiast owner/member
    Carmel
    let us know if this works... my spare is about 25' from the car.... might be a problem.
  19. mikeg561
    mikeg561 Member
    It works. Like I said, without the aluminum I could lock or unlock the doors. With the aluminum, I can not. I don't think there is any way to tell if the car has pinged the fob. Is there?
  20. GlmnAlyAirCar
    GlmnAlyAirCar Member
    Southeast PA
    Hmmm, I thought I was storing my key far enough from the car (approx. 17 ft.) but my fob went nearly dead (no auto-unlock, need repeated presses of unlock to make it happen) yesterday, just 10 weeks after getting the car new. The spare (kept further away in a fireproof safe) is fine. That seems pretty quick for the battery to die, even if kept within pinging range.
    Should I get the $1.99 battery on Amazon or the $600 battery at my first service? :wink:
