Yes, it will initiate a charge on its own. I believe the number is 3%, but I don’t recall for sure. Been a long time since I experimented with it.
I didn’t know opening the door would initiate a charge. I do know that opening the door will start the HVAC and start warming the battery. I can see it on the dash, even with a charge scheduled in the future. Many appreciate using shore power to get this going for range reasons.
Does it keep warming and charging if you don’t get in and just close the door?
I hear what your saying on overall energy wasting. I’m not convinced a wider hysteresis band is the solution.
Maybe charge slower so it doesn’t need a warm pack?
Or a battery pre-heat button to press before a trip so it doesn’t have to assume shore power is the right choice?
I really have no idea what it would really save. I highly suspect it much better than targeted charging finish in order to regain regen. I only noticed it do this once top off on it's own once. Maybe it was on the verge of doing the 3% thing you mentioned and when I opened the door it started cabin heat and it dropped enough to trip that 3% re-top off. I might have done some work in the car putting in a sunshade and it may have dropped enough.
I believe did shut the door and it look like it was just gonna do it's normal charge thing.
Setting the current limit low is a very interesting idea. That might just work.
Keep in mind the opening door thing was just one example and if it doesn't happen that often it's not a big deal. I think the hysteresis control could still be very helpful because of the overhead (Extra energy) in setting up a cold charge. You don't want to do that more than needed. Now it could also automatically lower the current to avoid heating. But it doesn't appear to do that.
As many Model S owners have suggested, just don't plug it in. I don't want to not plug it in. And the only way to get it to not charge is to constantly fiddle with the high limit.
