Home Charge Points Discussion and Suggestions [megathread]
They will probably fit an additional consumer unit if no space. TBH that is preferable anyhow - keeps prolonged high current out of an existing consumer unit.
Gen 3 TWC already has the DC protection built in so no need for B type RCD.
Earth protection is dependent on your current earthing arrangement. Electrician will tell you what additional protection is needed if any.
Thanks for the reply do they sell a consumer unit with earthing arrangement? As i think i will opt for that also? Many thanks for the help
Gen3 still needs supplemental earthing if the supply is PME, usually in the form of a rod. Had a Gen3 fitted in the (detached) garage last week, along with O-PEN protection in a separate box adjacent to the garage sub-panel. Fortunately, I had an earth rod fitted already as part of the PowerWall installation last month.
Steve
hi steve, any chance of a picture of your install or the o-pen device you have fitted? I wonder if i can get a open device with earth protection as i dont have earth rods as its also located in a garage. @scdoubleu
Hi, or would it be the case of fitting this?
Hi all im after some advice if anyone can help it would be greatly appreciated.
I plan on running a 6mm cable to a 32amp outlet on my hager board i have a spare zone (see picture circled in red)
Is this sufficient as im reading i need a type b rcd? And also surge protection And possibly pen device?
It is being installed by a qualified electrician but i want to make sure its done correctly myself and future proofed.
TYIA. Ben
Hi Ben,
It's a really easy install for your electrician. The way mine was done was like this....
My electrician installed a henly block after the meter and added a Garo G6EV40PME (essentially a new circuit) The Garo has built in PEN protection and breaker. The Tesla wall connector was then connected to the Garo.
let me know if you need more info
Reactions: 8enj
Oh and the Garo is much better built that the unit you posted (and cheaper) £130.54 delivered next day DPD from Fastlec
For clarity, I think I'm right in saying that this box doesn't cover the 6mA DC RCD protection (which isn't a problem so long as it's being used in conjunction with a charge point that already includes it.)
@Adopado i have the gen 3 latest charger?
Tesla Wall Connector Features​
  • Up to 44 miles of range per hour of charge for new vehicles
  • Type 2 handle
  • Max 32 amp output
  • Supports 400 V three-phase Wye, 230 V three-phase Delta and 230 V single-phase wye grid types
  • Supports TT, TN and IT grid types
  • Built in RCD Type A + DC 6mA protection ******* [Yes ...this bit!]
  • Wi-Fi connectivity (2.4 GHz 802.11 b/g/n)
  • Power sharing (up to four Wall Connectors)
  • 7.3 m (24 ft) cable length
  • Approved for indoor and outdoor installation (IP55)
  • Tempered white glass faceplate
  • Type 2 handle
  • Max 32 amp output
Perfect thanks
Sorry to necro this thread, but am I right in thinking if I have a Tesla Gen3 Wall Charger and my house is on a TT supply, then I just need over current protection in the consumer unit (40A for Single Phase) and a new Type B with 6mA DC protection would be just overkill (or belt and braces if you like)?
Hi i think the 6ma dc is built in on the gen 3 so you just need to the type b 40a i purchased this one @Washout
Reactions: Washout
