I'm also pondering this...
I think i would prefer to have it done at the house to make sure it can pair with the garage door while a tech is there.
Personally, even if they would let you, I wouldn't confuse pickup with getting accessories fitted.
Bit of dilemma paying for Homelink if you don't know if its going to work or not.
There is a (non exhaustive) compatibility guide at https://homelink.com/assets/downloads/homelink_ukenglish.pdf
We got 1 of our 3 remotes successfully paired - our basic 433Mhz ones didn't work. I could probably fit a compatibility unit to one of them such as Chamberlain Universal repeater but I won't know if it will work without opening my garage door controller and doing a bit more research.
As we ordered in May, it was part of spec, but if I paid £300 I would be a little disapointed that it doesn't seem to work with basic remotes. It will hopefully come into its own on the gates that it should open as that removes any need to fumble with remote whilst still on public road.
I have one of the Chamberlain Universal Repeaters and it works fine. You just need to run some bell wire from your existing garage door opener.
Despite reserving the car in July 2017 when homelink was free of charge, do they still charge for it as an add on now ?
Externally we have a single button on control that toggles through open, close, stop. On remote its separate open and close. So I am not sure how these will map on to each other. I probably just want to use car to open door - fine manually closing it. Until I open unit, I wont see how that single button is wired in. I've got install instructions for a slightly different version to ours, but that has 3 external buttons.
How do the 2 contacts on Chamberlain unit map onto control units. How do you tell homelink to differentiate between open and close - different profiles? I might be able to come up with a use for a second discreet channel...
Just spoke to Tesla. They can't do it until it's delivered but they will do it via the ranger service. They didn't know the cost but will get back to me.
