Attn: Jerome Guillen
I understand from your Hong Kong team that Tesla will not be providing any support for the BS1363 13A socket in Hong Kong.
Quite frankly, that is a mistake. It will lead to bad press, upset owners, cancelled orders, and a strong negative on the ownership experience.
I apologise for the length of this eMail. The short story is that I think your proposal of providing 32A HPWC for home use is a good idea, but you should offer a Mobile Connector style option using BS1363 - and that connector should only be provided to customers who sign a waiver and agree to follow the Hong Kong EMSD requirements and only use the connector on BS1363 sockets installed and dedicated to EV charging. If you are really concerned with suitability of this, then de-rate the connector to 10A. But, please, at least offer some support for public charging in Hong Kong.
Long Story:
Hong Kong currently has over 1,000 charging points. As of today, 992 of those are BS1363. The remaining are Chademo and Tesla HPC. There are essentially zero Mennekes style sockets available for public charging. So, in reality when you are saying no support for BS1363, you are saying no support for public charging in Hong Kong. No support at all. Roughly the equivalent of refusing support for J1772 in USA, Chademo in Japan, or 3 phase in Europe.
Putting aside the dubious usefulness of a 2 hour charge at 13A while visiting a shopping centre, there is a real use for BS1363 13A charges of 10hours or longer (either overnight at home, or during the day at the office). While 32A would be preferable, BS1363 13A is cheap, simple and universally available (and gives a 25+KWh top-up in 10 hours).
From a safety history point of view, there are currently 500+ EVs in Hong Kong, which have been safely charging on BS1363 13A for three years or more. Dozens of your own Tesla Roadster owners plug in and charge here at public BS1363 outlets every day. A large number of those would not be owners without the BS1363 charging option.
From a technical point of view, I understand the safety concerns. There are two sorts of BS1363 sockets available in Hong Kong today:
- Private sockets on the walls of homes, offices and garages. These often use the shared ring-main approach, and the wiring and quality of socket may be a concern.
- Public charging stations, which follow the EMSD (Government department here responsible for this) standards (published at this link). These use dedicated cables and 1-to-1 radial circuits, protected by RCDs and rated to 16A. The vast majority (>90%) of these are installed and run either by the government EMSD itself, or by the two electrical utility companies.
I agree that charging at generic BS1363 sockets may be potentially unsafe (depending on the quality of the wiring, and other loads on the same ring main). But, I disagree that charging at EMSD compliant charging sockets should be considered in any way unsafe - and all public charging sockets follow those requirements. The government is quite clear. The EMSD requirements are the statutory requirements and general guidelines for installation of charging facilities for electric vehicles (EV) in Hong Kong.
The proposal I have heard of providing HPWC stations limited to 32A, for home charging is a good one. There is little extra complexity with installing a 16A/32A circuit vs a 13A BS1363 socket in a garage / outside wall. For customers who can charge at home, this is a fantastic solution.
For public charging, I strongly suggest Tesla offer a Mobile Connector style option using BS1363 - and that connector should only be provided to customers who sign a waiver and agree to follow the EMSD requirements and only use the connector on BS1363 sockets installed and dedicated to EV charging. If you are really concerned with suitability of this, then de-rate the connector to 10A. But, please, at least offer some support for public charging in Hong Kong.
