Jeez this thread really blew up in a short time!
So. Hi, "that guy" here. Unfortunately I must embrace it, and recognise I'm the party pooper. Sorry.
There's some really really good advice in the OP, surrounded by some really false details, and also a bad suggestion or two. This does not eliminate the fact there are good points though, which I've summarised at the bottom.
I struggled with posting this, as it
seems combative and/or argumentative? But that isn't my intent.
@SomeJoe7777, this ain't your fault for "getting wrong" so please don't see it that way. Seems like you were fed a bad explanation IMO. This actually happens a lot from Tesla Service employees, unfortunately (as they're pressured into offering
some explanation with
their current understanding). You brought new information to us, which is very appreciated!
The open circuit voltage is indeed important, this has been known for a while but good to talk about directly (it gets lost in the misguided "balancing" threads every time). The voltage swings quite wildly when driving, but your battery gauge is resilient to these swings while still providing a very accurate report of remaining capacity. This is an admirable component of Tesla's battery meter.
There's much for the BMS to learn during a drive (changes during discharge and regen can reveal a lot), but a non-sagged open-circuit voltage is fairly representative of the battery state especially when battery temperature is also known (and indeed, it is to the car).
The bleed resistor thing sounds all wrong. Balancing setups generally aren't like this (maybe never?), for many reasons:
- The bleed resistors, for balancing, cannot (reasonably) be permanently draining
- By definition, the battery is not open-circuit if there's a reasonable load across any of the cells (e.g. for balancing)
- Being the "primary cause" of vampire drain measured in the wild would require some unrealistic values
- Stats says ~60W median for LR. 96 series bricks means each brick drains 0.625W
- Implies chonky 1W resistors. These would be visible on the BMS boards. I see no such resistors. I don't even see 1/4W ones.
- At 4.0V (reasonable guess of average SoC, ~73%), that implies a ~25 Ohm resistor. That is a very, very low value for a "bleed" resistor.
- If the bleed resistors were 10x higher (and always engaged), voltage would reach steady state faster, not slower. Higher resistance equals less power draw. Less power draw sags the battery voltage less. Less sag means being closer to steady state or "open-circuit".
- That would also imply 2.5 Ohm "bleed resistors" on S/X. This is more into current shunt territory than bleeds, and would indeed cause massive vampire drain if always engaged. But S/X are not that bad.
- Most importantly, bleeding all bricks simultaneously just wouldn't be an effective way to balance - no balance is actually occurring this way, just a fixed drain no matter what the capacity of that brick is, which would actually induce imbalance over time.
I find 3+ hours to stabilise voltages
incredibly hard to believe (yet I have no data to support this). What's more believable to me is that this is an upper bound for some common tasks Model 3 is doing before going to sleep:
- Sometimes the car fetches new firmware and/or map data after a drive. It seems to remain fully awake while it downloads. As downloads are large and the car often gets spotty WiFi (garage or outside), these take a while.
- Sometimes the car will upload data after a drive. See above, but note upload speeds are generally much slower on home internet.
- The blower will continue to run for a surprisingly long amount of time if the AC was on, to reduce condensation leading to the moldy smell.
- When the battery is very warm, it seems to stay awake longer (not necessarily using the chiller to cool it off, just running the pumps and going through the radiator).
Now, stabilised could've meant "balanced" I suppose, which
kind of makes sense in the post? But this doesn't seem right?
Anecdote time. It just so happens that ever since switching to 240V charging (months and months ago), our charging habits would be ideal for this OCV theory. Especially in the pandemic where we leave the car unplugged at various percentages now, it has more of a chance to gather more readings.
The result of that? The reported capacity plummeted nearly all at once,
no gain. It also still varies +-1% despite all this seemingly good data it should be getting. And where it ended up seems about right for a healthy battery, reporting about 5% degradation on a car with 40,000km on it.
What I mean to highlight by this is that, if true, it can go both directions. One person may "gain" range, another may "lose" it.
I'd put these as the "good takeaways" of the OP.
- Let your car sleep. This has multiple benefits, but accurate measurement is one!
- Yes, don't run Sentry 24/7. Car wasn't designed to be a dashcam, and does that job poorly.
- Any "calibration" is just that, and hasn't increased the actual capacity of the battery.
And don't do these:
- Don't: Charge to 100% to "balance". This happens at lower percentages anyways as well, and balancing to an uncommon state actually offsets it in a non-ideal way. Balancing would also take a lot of time, so doing this right before a trip doesn't accomplish that anyways.
- Don't: Skip charging to provide more data points. While I've found some vampire drain benefits to being unplugged, not having the capacity when you suddenly find need for it is not good. There is no sense in stranding yourself because you left the car unplugged at 20% just so the battery meter is very very slightly more accurate. That's like 50mi of range of a brand new SR+ in ideal conditions on flat ground.
- Don't: Take TeslaFi/Stats/etc. graphs as accurate. There's so many problems with the way these report capacity in general, and can paint pictures that don't reflect reality.
- Don't: Take Tesla Service's guidance on everything regarding batteries. Some do have some generally good advice, but some have their own wild theories. They are often not battery experts, they are mechanics. That said, don't take some internet dude's advice either, me included!
Rapid question answering time! (it seemed like most of these weren't responded to)
Does leaving climate controls on cause the battery not to sleep and any thoughts on what to do when I have to park outside with no shade and a month straight of temps near or over 100 degrees.
I have seen a significant loss in displayed range and I can’t help but feel like it is from my vehicle running the air to keep the computers cool. Any thoughts or input on this?
Yes. The AC and heater are both high-voltage components and will draw from the battery at all times if on.
My suggestion would be to not leave the climate controls on. Turning them on even just 2 minutes before you get in the car does wonders, if possible (I realise connectivity can be an issue in some places).
If you have Cabin Overheat Protection on (it is by default), that could explain some of your drain (but it doesn't run that if it hasn't been driven for more than 12 hours). The computers are actually liquid cooled, and the AC wouldn't need to run for that (just passive heat rejection via the coolant loop and radiator is way more than enough).
I was going to ask this, but really this is just to let the car recalibrate what it thinks it has capacity wise. It has no actual effect on capacity or health of the pack, just how it is reported, is that correct?
Mostly, yes. Small effective capacity gains may happen via balancing, but that's a whole separate topic IMO. If there are gains to be had by balancing, they are small. If you have significantly reduced capacity due to balance issues, you have a physical battery issue that is beyond correctable by balancing.
Great information in this post. Here's how I think it applies to my situation, given this background:
I have a 2019 M3LR AWD (Scarlett) that started its life with my wife and I in July, 2019. When I drove out of the parking lot, its range showed 315. In the year that we have driven it, we have covered just over 7,000 miles. We're seniors, and retired - no jobs or daily driving unless we want to go somewhere. Scarlett gets a lot of 'garage time', with Scarlett sleeping roughly 10 hours per day. I charge when the range gets down to between 45 and 85 miles indicated, and charge up to 80%. I've charged to 100% only four or five times so far, and always just before a trip. And, since we live in the Phoenix area, we have some 'VERY' hot weather (50 days this year over 110), which affects not only people, but Scarlett's battery. When we return home from errands, the temperature in the garage is still in the mid to high 90's, so Scarlett cools down slowly and uses quite a bit of energy for extended periods to cool down the battery. [Incidentally, the Cabin Overheat Protection feature is awesome.]
Following the logic we're discussing, BMS has plenty of time to recalculate range. So, I believe that Scarlett is telling me as close to the truth as it can. I charged last night, and 80% tells me that I have 268 miles. If we start with the 315 number, times 80%, that number should be 252. So, Scarlett is saying I really have 85%. Nice!
Any holes in the logic here?
The hole may be this: are you sure it's exactly 80% with 268 miles reported? Probably not, it's really hard to get it to hit 80% exactly.
isn’t battery/range also affected by temperatures? Especially reduced range in cold weather?
Yes. Up to about 3% before you see the "snowflake", and presumably more after that. It's gradual.
My LR AWD range has been steadily declining over the past 2 years and I'm nearly at the level the OP has at 272 miles at 100% SOC. I've tried lots of "calibrations" with no luck. However, this information is promising so I'll try this too with some hope. My commute is 130 miles roundtrip so I usually charge daily but I will try to rest the battery at different SOC's and see if it helps. Thank you for this info. Here's hoping.
Edit, forgot to mention, I just had my battery breather valves replaces this week due to unusual loud pops when supercharging. Coincidentally, I lost another 8 miles of range shortly after. Unsure if it had anything to do with it.
Replacing the breather valves would have nothing to do with your battery capacity, measured or real. I don't think they even do a high-voltage disconnect for this procedure, so your car may literally not notice anything being done to it.
So, to me, that is another trade-off. It sounds like you could be slowly degrading your battery more so that you can get better capacity readings from the BMS.
I tend to try to keep my battery in the 40%-80% range nearly all the time and only go above or below for a rare long distance road trip.
Personally, if I felt my range indicator was to drift too far from (what I think is) battery reality, I would do a one time skip on charging, and one time charge to 90% just to get more readings, but I wouldn't make it a habit of letting it get down to 20% on a regular basis.
This is absolutely the case and understanding outside this thread, yes. Most "calibration" procedures, recommended either here or by Tesla, do technically wear the battery more than otherwise.
I guess I don't understand. If there is really a suggested regime for charging to make the battery last as long as possible it should be in the user manual. If not, why not? Either Tesla stands behind the charging regime or they don't. We shouldn't have to guess at this. Here is an idea - put an option on the menu that forces the Tesla to do whatever it has to correctly estimate the true range of the current battery (hey Tesla could call this a new feature!).
If it's not made clear by this thread, there are too many variables at play to make a blanket suggestion for charging habits that is beneficial to everyone.
The singular clear thing is that charging above 90% routinely is almost never good, and
that is the one recommendation they're aggressive about (the car will even warn you if you charge to 100% multiple times in a row). Anything further recommendation needs to account for too many local variables and personal use-cases.
Agreed. It appears to be rather too variable for people to fully comprehend. People aren't used to the size of their gas tank changing with temperature, for example.
But I'd argue that when the range shows a particular number, it really is an extremely accurate estimate (within 1-2% I would think, not including the buffer) of actual energy available at that point in time at that pack temperature.
I think we generally understand from SMT that (for Model 3) there is a 4.5% buffer below 0 rated miles, which is part of the available pack energy, which is not *exactly* shown on the display. But this manifests as each rated mile containing roughly 234Wh/rmi (pre-2020 AWD M3) rather than 245Wh/rmi (which is the actual total available energy content of the battery, including the buffer, when you take the number of rated miles at 100% and multiply by that scalar). These values differ by 4.5% of course. This results in about 4.5% of pack energy being available still when you hit 0 rated miles. Hard to say how much of that is truly usable though. Don't want to press that accelerator too hard at that point or you'll get a brownout (hopefully not in your shorts though)!
Tesla definitely doesn't want to have the car shutting down when you hit 0 rated miles (or slightly before). That seems to me to be the reason for the buffer.
I suspect the unreliability of the below-0 capacity is due to voltage sag. They start cutting max power
heavily at low SoC to prevent voltage sag from going outside the boundaries of heavy damage (made worse by the reality of higher sag at low SoC). My guess is they cut the battery out the moment a cell exceeds or touches a voltage threshold. You'd be especially at the mercy of cell variances at this point too.
