The reason I don't charge to 100% is not that I care about saving the battery, it is about saving time at superchargers.No need to be an armchair engineer: use every bit of the range available before your road trips.
That doesn't make sense. Yes, you charge faster at low SOC... but when do you stop charging? When you've hit a certain SOC (whatever's required to get to your next stop/destination), or when you've hit a certain number of kWh added?The reason I don't charge to 100% is not that I care about saving the battery, it is about saving time at superchargers.
For my trips my first charger stop is always about 1.75 hrs from our house. If I charge to 100% then I will arrive there at a much higher SoC than if I left the house at 60%. Leaving the house at 60% has me arriving at sub 15% resulting in higher charging speeds and a shorter stop. I try and always stay below 60% which keeps all my stops around 10 mins or so.
Obviously if you need the range between SCs then go higher, but I find many people charge to 100% and don't need to. If you want to eliminate range anxiety then sure, fill your boots/whatever works for you.
I was probably trying to shorten my response too much and be too generic with my numbers.That doesn't make sense. ...snip
Yes, that principle is correct, but does NOT apply for the initial charge before a road trip. As @gtae07 clearly explained, you'll always spend less total charging time on a road trip by starting out with more charge. So go ahead and charge to 100% immediately before a road trip: it saves total road charging time and does not hurt the vehicle.My general idea is more stops at lower SoC than fewer stops for higher charges.
Charge to 100% right before a trip if you need the range. I do it once every week or two to get to work and home without needing to supercharge on the way home.MYLR, In daily use where you charge to the recommended 80%, how often do you charge to 100% to calibrate the battery, or do you do it at all, apart from long trips?
I never said anything about having to make a long charge stop. Yes, you want to arrive at chargers with the lowest charge you are comfortable with--but if you arrive at that first stop with a higher SOC, just don't charge for as long. Or, depending on where the stops are, you could possibly just skip the first charge altogether.I was probably trying to shorten my response too much and be too generic with my numbers.
My general idea is more stops at lower SoC than fewer stops for higher charges. For my most travelled route I hit 3 chargers for around 10 mins each. It's possible that I leave home with 100% and only hit one charger, but I would be there for more than 30 mins. Plus as I need to stop at least two times it makes sense for three short charges instead of 1 long charge stop plus one nature stop.
Again, depends on your own setting but this works out faster for my trip.
Eh? You bet, whatever works you.I never said anything about having to make a long charge stop.
