WileyTheMan
Peanut Gallery Member
Yeah. Demanding always gets you what you want from a landlord. lol!...and demand that they get with it and install the charger asap.
Spoken like a renter with a huge sense of entitlement. Who are you to DEMAND that a landlord spend money on a device that far fewer than 1% of renters could use?…and demand that they get with it and install the charger asap. An electric car charger would only add value to the rental unit/property, which means that the costs should be 100% on the landlord.
I had an idea. There is a condemned house a few miles away. It was foreclosed on and it is a wreck. If all else fails, maybe I can buy it super cheap and just fix the breaker box enough to charge the car, and do no other improvements.
Can you tell us a little more about what the existing layout of the house is? Does it have electric or gas appliances? Is there a laundry room relatively close to where you park? If so, you could plug in something like a Dryer Buddy to split the existing dryer plug (10-30 or 14-30) so that it could be used by both the dryer or the car (one at a time). It wouldn't require any installation and you could take it with you when you move.
Or, if all else fails and you decide to stay one more year, you could purchase the 20A adapter. You would just need to have 20A plugs and breaker in order to utilize this. This plug will charge one-third faster than the 15A plug that comes with the car. You will receive about 1,750 watts per hour, or 5-6 miles of range added. A twelve-hour overnight charge would boost your battery by 60-70 miles of range.
Everything else is electric including the dryer. The laundry room is adjacent to the garage. Enter the house from the garage and the laundry room is immediately to the right and shares a wall with the garage, although the outlet is not on the shared wall. I don't see any way to share that outlet without having a charging cable running out of the laundry and through the door leading to the garage which would prevent the door from closing.
