@Georgesb2 I think the only real performance benefit to bigger diameter wheels, is fitting bigger brakes inside. The 20" M3P wheel diameter is just for looks, it's actually worse for performance due to the weight. Some other car companies will at least make their big flashy performance wheels forged, but Tesla does not, they are super heavy and are literally a drag on performance, as well as at risk of damage.I have the stock Pirelli PZ4. The road noise is a bit loud on the rough type asphalt. The car performs really well. I've put it into 4 wheel drifts, so I suppose they could have more grip, but that's a tradeoff. I've considered 18" wheels. What wheels did you get? I don't think I want any more road noise however....
The 18" is supposed to get better range. Does it make much / enough range difference. Also as far as cornering, don't you lose some with the bigger tires? I assumed a small tire / large wheel combo was best for cornering?
Short sidewalls can certainly help with steering response, but tires can be built to be responsive even with taller sidewalls. I picked tires that reviews said were especially responsive, and I think it worked out well. This is the 3rd car I've downsized wheels on. The first time was winter wheels for an ICE car (I continued using its original wheels for summer), 2nd time was the year-round wheels for our Model S, see below.
18" is a tight squeeze over the M3P brakes though, especially the parking brakes in the rear. Some 18" wheels fit, like the ones I got which are in an M3P specific spec, but I can see why Tesla would not want to offer 18" as a factory fitment over these brakes. 19" is an easier fit though, and certainly a better tradeoff than 20" of looks vs practicality. There is really no reason for 20" with our brakes.
My goal for downsizing was to not risk cracked rims, pinch flats, etc. Our S P85 came with 245/35, very similar to M3P 235/35, and one of its wheels cracked just from driving down a very rough road. I had to argue very firmly with Tesla service just to get it replaced as a goodwill item. After that and another incident we downsized to 2" smaller diameter wheels (smaller Tesla OE wheels) and no more cracked wheels.
For the M3P, since apparently the regular Model 3 18" wheels don't fit over the brakes, I went with Titan7 T-S5 in 18x8.5" ET35. They are fully forged (not "rotary forged" which is just flow formed cast, which is fine tech but not the same as a true forged wheel), at the cheap end for true forged wheels. Honestly in 18" flow formed cast should be fine, but I wanted the extra strength from forging, and the price ($2k/set a year ago) was just low enough for me. Also Titan 7 offers specs meant exactly for this car, even machined for the "stepped lip," which many wheel brands don't bother with. There are other good brands that do too though.
For tires I went with Bridgestone Potenza Sport 245/45R18 300TW, in the same "max performance" class as the OE PZ4 tires. So 10mm wider tires, mounted onto 0.5" narrower wheels. 245mm on 8.5" wide wheels is a 100% normal fitment, that's what our Model S came with, and what my last ICE car came with too. Whereas the M3P OE fitment of 235mm on 9" wide wheels is visibly stretched...I don't understand why Tesla chose it.
First thing I noticed, even more than I expected, was how the steering felt lighter and more responsive. I chalk that up to the wheels being much much lighter. I never weighed either wheel, I wasn't really concerned about that, but having carried each wheel+tire combo I can tell you the new setup is significantly lighter. Quick back-and-forth steering in tight twisty roads just feels easier now, almost as if the power steering was slightly struggling before.
Next thing I noticed is these tires (no foam liner, unlike Tesla OE tires) are a little louder when cruising around. Not a huge difference and not too loud for me, I've had much louder performance tires on past cars, but they are not as quiet cruising on the highway as the PZ4 were. Even at local road speeds I can tell they are louder. I haven't found them objectionable, nor has my wife, but they aren't as quiet as the PZ4.
Once the tires wore in, my first grip comparisons were in the wet, and I swore they felt like they gripped as good in the wet (damp, not deep standing water!) as the OE PZ4 did in the dry. In the dry they were even better. Also, the squealing that had mildly annoyed me with the PZ4 is gone with these tires. (I've not had any issues with hydroplaning with either tire, though I take it easy through anything that looks deep.) These tires are 10mm wider as mentioned, but that is a pretty small width change, I think they just perform better overall.
Finally, efficiency. I was worried I'd lose efficiency, because my new wheels don't look aerodynamic at all, and Tesla tends to pick efficient tires as OE tires, so my tire choice could be worse too. Well, not to worry! I definitely gained efficiency. I can cruise at 72-73mph on the highway, climate control on of course, and match the car's EPA rating (if flat highway, no rain or big winds, etc). Efficiency seemed to go up for long drives on winding rural roads too, again much easier to meet the car's EPA rating. However I don't want to put firm numbers on the improvement, because my driving is NOT very consistent, and I never attempted any kind of controlled test.
Why is this setup more efficient? My best guess is twofold:
1) The significantly lighter overall wheel+tire weight.
2) Taller sidewall / smaller diameter wheel probably helps aerodynamics.
Are the tires I chose more efficient too? It's possible, but I am doubtful. I credit these tires for the improved grip, but not for the improved efficiency. Tires certainly matter for efficiency too! Just in this particular case, I credit the wheels.
A few more thoughts: People here who are into drag racing have shown consistent if small improvements from switching their M3P to (lighter) 18" wheels (from 20"). I'm not really into that and I couldn't "feel" any acceleration difference, but apparently if you measure it, there is a small improvement in 0-60, 1/4 mile, etc. Not drastic but it's consistent when isolated from other factors. (Battery temp, battery SoC, etc are bigger factors.)
I couldn't feel any loss of steering response from the change, and that is something I care about (more than 0-60). I did pick a tire (Potenza Sport) that reviews said was particularly good for steering response though, with sturdy-feeling sidewalls. In my experience changing wheel sizes on other cars, if you downsize with a tire that's a little mushy, then the taller sidewall can really accentuate it, so pairing the right tire and wheel together is important.
Also, the Model 3 has kind of rubbery steering from the factory (at least for the 2021's that I've driven - tested 2 and bought 1). I have since upgraded my suspension including some bushing upgrades (long after the wheel+tire change), and I suspect I could now make out more subtle changes in steering response. But I have not put my original wheels back on for comparison.
