I don’t trust HP numbers from Tesla ..I was one of the guys who bought a “691hp” P85D
early on ...
I agree. The "motor power" thing, which terms Elon did use in "The Announcement", has been a sore spot that bears revisiting. The P85D shares hardware with P100D, but because of battery amp output limits of ~1300 was closer to a (still massive) 500hp. The new fuse achieved higher limits, which were then exceeded again as battery size increased. I am not sure, but believe somewhere in there the PXXD became a "motor limited" rather than "battery limited" car. M3P, per Ingeneer's video has a 1,200 amp limit. Add lighter weight, and that's good potential, but also a smaller battery.
RE: 1/4 mile trap speeds. One thing blurring the HP max is how low, in speed, it happens in the single-gear car. Here, too, the PD Model S cars peaked out at around 40mph. As already noted, it may be that this lower peak is software blunted for non-M3P. Regardless, the HP at high trap speed being so far away from the peak HP at ~35-45mph, of a single geared vehicle, would not necessarily suggest the peaks would be near equal.
Top end has always been a big deal for single-geared EVs. I'm not here to push competitors, but Rimac and I am betting Taycan are 2-geared in order to perform better at illegal US speeds; better roll-on, highway passing, etc. Tesla has gotten around single gear limits, to an extent, by using massive batteries. Just as the top end of the 85 was always better than the 60 (RWD), the fall from the brutal torque/HP spike of P85D was a bit faster than later versions (once you get past 50-60mph).
Since I'm spilling my own views (not necessarily correct ones?), I would add power decline as SOC drops also showed different dynamics in higher amped PDs. My M3P test drive was with 120 miles of range left. Stepping out of the P85D, I wasn't impressed but knew that like my car, the M3P probably suffers from performance decline as SOC drops. People criticize EVs for this unevenness. Big batteries mostly take care of it for Tesla (closing in on the fuse limits, for longer durations), but the two relatives of at-what-speed the HP peak is happening, and rate overall battery output (and thus, KW or HP) declines, should be important for anyone looking to get their head around BEV performance.
