Replying to a lot of posts over several days. Sorry for the long post.
If you are talking direct solar split, then given that the
current efficiency is ~15% are you either ignoring the fact your fanciful 36% target is over 2X what's currently possible, or hoping for some technology in the future that may not exist? If the latter, why are you advocating for it now?
Interestingly you inserted a link for the 15% efficiency claim, but neglected to mention that others have reached 19%.
https://pubs.acs.org/doi/10.1021/acsenergylett.8b00920
Promising speed of improvement.
If you aren't using solar panels, then you're comparing apples and oranges. The state of the art as far as solar power conversion efficiency goes, is from solar thermal generation stations, which have efficiency around 50%. So even 36% would still be a total joke — 19% approximately doubly so.
About 5.7 million tons of by-product hydrogengas, nearly equivalent to half of annual industry hydrogen consumption, are produced from coke and chlor-alkali processes. Only a small amount of the by-product hydrogen produced is used on-site to produce hydrochloric acid (HCl) in some facilities, while larger portions are either used as process fuel, or sold for town gas. In some instances, it is wasted and evacuated to the air without any utilization,accounting for nearly 3.0 million tons annually.'
So what you have here is an industrial process that releases most of the hydrogen that it produces. Ask yourself this: Given how easy it is to burn hydrogen as fuel, if it were worth the effort, don't you'd think they would be capturing it and producing electricity already? From this, we can infer that the cost of collecting the hydrogen exceeds its value, and that equation will not change with hydrogen cars, because it will still be cheaper to produce new hydrogen with electricity than to capture those waste products. Were that not the case, it would also be worth capturing that hydrogen and turning it into electricity. (Okay, in theory, if it is currently only unprofitable by one or two percent, it
might be
barely financially viable, but that's noise.)
Besides, 3 million tons of hydrogen isn't much. That's only about 2.7 billion kg. One kg of gas is, I believe, roughly equivalent to a gallon of gas in terms of its ability to move cars, and the U.S. alone used 142.86 billion gallons of gasoline in 2018. Therefore, all the wasted hydrogen in the world would still replace less than 1.9% of U.S. gasoline consumption. Compared with the double-digit efficiency loss resulting from using hydrogen instead of a battery, that bonus 1.9% is lost in the noise. And even if it weren't, you'd still be much better off burning the hydrogen on-site and turning it into electricity.
No, EV charging stations don't need much real estate. They need much less than 1 parking space ...
I assume you mean on top of the one space per vehicle, because otherwise, I'm seriously impressed at your car-stacking charging station.
Yep the forum of hydrogen experts are so excited about H2 being dead-end technology that none quotes any latest development in the field, e.g. this international R&D headed by Lancaster University is probably worth throwing in another few billions to explore.
The fossil fuel industry has a vested interest in keeping everyone hooked. Wherever there is money, there are people excited to take the money and do research with it.
Professor Antonelli, Chair in Physical
Chemistry at Lancaster University and who
has been researching this area for more than 15 years, said: “
The cost of manufacturing our material is so low, and the energy density it can store is so much higher than a lithium ion battery, that we could see
hydrogen fuel cell systems that cost five times less than lithium ion batteries as well as providing a much longer range – potentially
enabling journeys up to around four or five times longer between fill-ups.”
All of this is entirely moot. The limiting factor is the fact that A. the cost of producing the hydrogen cannot realistically ever be less than the cost of producing an equivalent amount of electricity, and B. it would have to be around a third the cost of producing the equivalent amount of electricity to cancel out all the other efficiency losses that occur at every stage along the way when using hydrogen as a fuel source.
Probably good to go back to this diagram:
Compression only loses 10% so even if you have a great improvement in compression for storage, it doesn't make much difference in the pathetic overall efficiency of the fuel cell system.
There's no way that power grid distribution results in 10% loss, realistically. The average, at least in the U.S., is only 5%. Besides, why would you include that on the EV side and not on the FCV side? Either the AC goes over the grid or it doesn't, and that's independent of whether you're using it to charge a car or produce hydrogen. So I would argue that the efficiency of the FCVs ought to be 5% lower, and the EVs ~5.55% higher (95/90).
"Hydrogen is one of the few ways of storing that variable energy. Other options include lithium-ion batteries — which power smartphones and electric cars — but they can’t compete with hydrogen in terms of scale. A big hydrogen storage facility in Texas, for instance, can hold about 1,000 times as much electricity as the world’s largest lithium-ion battery complex, in South Australia."
Absolutely. Hydrogen
might eventually make sense as bulk storage for the grid. It won't be done with fuel cells, though. They're far too expensive to use at scale. Rather, they'll produce hydrogen in bulk — probably thermally with steam reforming, but possibly by electrolysis — and store it at low density (no compression penalty), then
burn it to spin turbines.
That said, the reason it probably won't ever make sense even for grid storage is that pumped water energy storage is 70–87% efficient
today, and flywheels can achieve up to 85% efficiency
today, whereas steam reforming of hydrogen (currently the most efficient approach) is only 70–85% efficient
before you factor in the additional losses from converting it back into electricity, which yields only about 45–51% total efficiency today. So it would need to get half again more efficient to compete in today's economy. That is within the realm of possibility, but pretty unlikely (particularly because any efficiency improvements on the turbine side would also likely improve the efficiency of pumped water energy storage).
If only there were a way to do distributed stationery storage situated near the consumption point...
You mean like the Post-It® notes in the supply closet at work?
Now these upcoming rechargeable battery techs improve charge/discharge/energy density/safety, but is there any that can provide 1% discharge after 10 years stored in a cave?
No, including hydrogen fuel cells. All fuel-cell-based cars require a battery, because fuel cells can't ramp up quickly enough, and even if we ignore vampire drain, even if we assume that the battery is a Lithium ion pack, it will still be approximately flat from self-discharge in ten years, by which time the fuel cell will have long since kicked in to bring it back up out of the danger zone to avoid hardware damage. But if you consider a NiMH battery like they use in some FCVs, it will be completely dead within
two years from self-discharge, so the fuel cell will have charged the pack at least five times, which is an 8 kWh loss, or ~9% total discharge.
And that's only half the story, if the vehicle happens to have the same level of vampire drain that Tesla cars have, it won't even last as long as the battery in a Tesla, thanks to the higher self-discharge of the NiMH batteries.
