The Tesla battery is an AGM deep cycle battery (ie. marine, etc usage). 12 Volt Battery Compendium – TeslaTap
Look at graphics of the DC-DC converter charging voltage
1) before the install
2) during OTA install where the software for the DC-DC convert will be logically be "OFF" and the 12v is on it's own >> key point <<
3) after the install for X number of hours
From article and quote below: Marine Battery Maintenance 101 - e Marine Systems
*** "taken to 14.2-14.4 VDC before it is fully charged"
*** "Once fully charged, marine batteries should be held at a considerably lower voltage to maintain their charge - typically 13.2 to 13.4 volts."
I used the following device during the 2020.40.4 update a couple nights ago on a 12v battery that is only a few days old.
Aside: During a multi-state road trip my 2020.40.3 left my 12v battery in a bad state. I was jumped and then the install finished. The next day I drove to a Service Center that installed a new battery. Much longer version to that story. I was in NH that doesn't have Service Centers (as it turns out).
https://smile.amazon.com/QUICKLYNKS-Battery-Monitor-Bluetooth-Device/dp/B01MT4583U
Graphic below: https://i.imgur.com/PmFNdFS.jpg
White Xs were used to 'find' 14v. Blue line shows 14v relative to green app data plotted line.
Graphic below: https://i.imgur.com/rmGaBi2.jpg
Why Marine Batteries Fail -- When a lead-acid battery is discharged, a soft lead sulfate material forms on the battery plates. During the battery's recharge, this material is lifted off the plates and recombined into the battery's electrolyte solution. If, however, the battery is left in a partial state of discharge for as short as 3 days, the lead sulfate material will begin to harden and crystallize, forming a permanent insulating barrier. As this barrier becomes thicker and thicker, the battery's ability to accept a charge or deliver energy is diminished, resulting in the perception that the battery is no longer usable. The accumulation of such deposits, otherwise known as sulfation, is the most destructive process in the life of any lead-acid battery.
Multi-stage Battery Charging -- A typical 12-volt lead-acid battery must be taken to approximately 14.2-14.4 VDC before it is fully charged. (For 24 volt systems, double these figures.) If taken to a lesser voltage level, some of the sulfate deposits that form during discharge will remain on the plates. Over time, these deposits will cause a 200 amp-hour battery to act more like a 100 amp-hour battery, and battery life will be considerably shortened. Once fully charged, marine batteries should be held at a considerably lower voltage to maintain their charge - typically 13.2 to 13.4 volts. Higher voltage levels will "gas" the battery and boil off electrolyte, again shortening battery life.
![VS1DWng.jpg](https://i.imgur.com/VS1DWng.jpg)
![PmFNdFS.jpg](https://i.imgur.com/PmFNdFS.jpg)
![rmGaBi2.jpg](https://i.imgur.com/rmGaBi2.jpg)
