repair estimate August 11th! 5 days from now and a week after the storm hit!
Power came back. Total off grid run time for me was 49 hours 27 mins.
As I’ve been running in my ‘extended offgrid testing mode’ before I get my official PTO I’ve discovered a few things which I think could come in very helpful in the event of a real extended power outage. I’ve been going on grid for short times as necessary, but so far my longest stint completely off grid has been 228 hours and 33 minutes. I’ve spent a total of 921 hours off grid since my system was installed a bit more than a month ago. Obviously some of this may not apply to people with different sized systems.
First, I discovered that I have no problem making it through the night with my four powerwalls. On a typical day my solar production starts really dropping off around 7:00 or 7:30pm. Up until that time the PV production can support the house with some left over for charging the powerwalls, but at that time the production goes down and if the house is drawing a lot, because of my AC compressor or whatever it will start drawing some power from the powerwalls, then by about 8pm the solar production stops and I’m completely running on the powerwalls until the next morning.
With my normal overnight usage I’ll use about 50% of the power in the powerwalls by morning. So this means that if they’re at 100% by 7pm, then I can expect them to be around 50% by the next morning. However, I’ve had some days where it’s been cloudy and rainy, especially in the afternoons. In that case my house will start relying on the powerwalls well before 7pm and in the worst case, if the weather is bad enough during the day then it might not even have a full charge to start with.
I had one day where it was pretty cloudy all day and the powerwalls only got up to about 85% by 3pm, then it just rained for the rest of the day and I got a little PV production, but very little. By 7pm the powerwalls were down to 68% and by morning they were down to about 18%. Even in that case I was able to make it through the night with my normal usage, and luckily the next day was pretty sunny, but I’m not sure how well I’d do with two or three cloudy and rainy days in a row.
On sunny days, especially when I have several sunny days in a row and the powerwalls don’t deplete too much overnight I find that the powerwalls will be fully charged by about 2 or 3PM, which is right in the middle of my peak production times. On those days I have a good 5 or 10kWh more than the house needs that I can put into my car or use otherwise.
Especially since the weather is so unpredictable here in Florida I have found that I do try to shift things like running the dishwasher or doing laundry to the afternoons of sunny days when I know that I have excess power available. I certainly have enough capacity in the powerwalls that I could do those things at night, but I tend to feel like doing that is kind of borrowing from the next day’s solar production. That’s great if I have a sunny day and can get the powerwalls back up to 100%, but if the next day winds up being cloudy and rainy then I might have ‘borrowed’ too much power and I’m not able to get the powerwalls fully charged.
Overall though, short of charging the car, I have discovered that I can easily run my house off grid for extended times, at least during the summer. I certainly hope I’ll have PTO by the time winter comes, but I may still try to do another extended off grid test in December or January and see how well I can do during that time.
It's definitely worth doing (just noting that different utility agreements may have different verbiage with respect to how allowable off-grid operations are, pre-PTO.)Very impressive. I am also waiting for PTO and your story has inspired me to make
this weekend an off-grid weekend. We only have 2 PWs but I should find out now, before PSPS season, if I need to get a 3rd!
Do you experience any side effects from the inverter frequency being raised to control the output of the PV as the Powerwall charge cycles up and down from 100% during the day?
Yeah, to me this is a concern. It's why I haven't pulled the plug and stayed disconnected from the grid. In the app and on my own monitoring with pvoutput.org, I see prolonged periods (2-10 min) where the system is exporting or importing from the grid. It's not a lot, few hundred watts, but it's enough to make me think the grid is acting as a stabilizing factor in the entire setup. This is particularly noticeable when the powerwalls are doing firmware upgrades, or there are large changes in load (i.e. wife has the oven on and one or both AC units kicks on in short order).
I have not, although I was able to get Tesla to change the max frequency to 62.5Hz on install day, so I have no experience with the 65Hz frequency. I also try to avoid getting to that point. Instead of letting the system turn off the power and ‘waste’ it I will plug in my car to let it charge to use some of the excess power when I see the powerwalls getting up to 95 or 96%.
However, there have definitely been times where the system has raised the frequency and shut off the inverters, either because the powerwalls got charged faster than I was anticipating and I didn’t get the car set to charge in time, or the car wasn’t at my house or was already full. I haven’t noticed any side effects during those times. 100% of my light bulbs are LED and I have seen no issues with those, I have 60+ Z-Wave devices and I have seen no issues with those. I have one low end APC UPS and it has no problems, nor do I have a problem with my microwave during the high frequency periods.
