Wow, this is one of the worst EV ideas I’ve heard in a long time... none of those places see enough EV traffic for any business in the town to foot the bill for $10K+ or whatever for a DC charging station—not in the next few decades.
I think the light bulb came on at the end here... I'm not talking about TODAY, but in the NEXT FEW DECADES.
All those little towns you referenced have gasoline stations that cost MANY multiples more to install than a DC charger. $10k is the cost of a premium Coke machine, by the way. If EVs catch on, like the must, all the back water places will be decades behind, but they will eventually adopt the status quo.
I suspect that a future 5-10kW DC charger on that same 208/240 volt AC circuit on a 30, 40 or 50 amp circuit would only cost $2000, not $10k. And, it could plug in EXACLY the same way that a UMC plugs in.
Like it or not, for EVs to become mass market also means that competitive price issues will be paramount. If leaving out a spare tire saves them a lot of money (over the cost of a subscription service to change the tire), or leaving out a $1000 - $2000 onboard charger, I'm VERY confident that my "worst idea" will be the norm, particularly for low end cars.
The manufacturer can advertise that stripped down car for a really low price, and then "bump" the buyer for the charger (if they don't already have one).
The car is lighter and cheaper. You still have the OPTION to buy an onboard AC powered charger.
Also, just like you toss in that UMC in the back of your car, you could do the same with a 5-10kW portable DC charger, just like the guys did with an EV1. It just won't be light to lift, but very nearly the same weight as an existing onboard AC powered charger and UMC together. You would only do that with your stripped down low cost EV when you were driving someplace that didn't have charging, which will be RARE in the decades ahead.
- - - Updated - - -
The early CHAdeMO's were almost all 25 kW, which is DC L1. A slew of the "new" CCS ones installed at BMW dealerships are L1 [edit- "low powered"]
You seem a bit hung up on nomenclature, but the real problem is your facts are wrong.
There are almost NONE of the 25kW CHAdeMO chargers deployed. 25kW is VERY rare (65 amps or less). The norm is 115-125 amps and advertised as 44kW to 62.5kW, which in reality is:
120 amps *
300 volts = 36kW (this would be a depleted battery modern EV)
120 amps *
380 volts = 45.6kW (about peak battery voltage at 120 amps for a modern EV)
120 amps *
500 volts = 60kW (no current road legal EV has a battery over 403 volts, so not possible)
The CCS equipment, if included in a CHAdeMO dual unit, will be the same as above.
The individual CCS charge units provided by BMW/VW through Bosch are the quite lower powered units, about 60 amps, and therefore half the speed of above:
60 amps *
300 volts = 18kW (this would be a depleted battery modern EV, like a BMW i3)
60 amps *
380 volts = 23kW (about peak battery voltage at 60 amps for a modern EV)
60 amps *
500 volts = 30kW (not possible, since no modern car is over 403 volts, including a Tesla or BMW)
- - - Updated - - -
Do the math... Therefore, the only place to put public money in the near term that makes sense is to help support the real destination charging network - which is 10-19 kW J1772 AC charging in the U.S.
I can't help but cringe to see something so shortsighted. Thankfully, your vision isn't even considered.
