Seat occupancy sensor may need to be calibrated. Take out car seats, undo seat-belt and reboot (scroll wheel method). Then put your car-seat back in using a seat protector with plastic support ribs. (some car-seats trigger the occupancy sensor either their weight or their shape) This worked for my false seat-belt warning.I never had an issue with car seats in the middle row but after 8.0 last night it seems to think the seat is occupied and needs buckling (with car seats in it).
The exclamation point drove me nuts enough to pull over and Buckle the seat-belt behind the car seat to have the warning turn off.
Another thing to check is the rear car seat strap, It tends to slip down the side of the head rest, this adds pressure to the occupancy sensor and is perceived as an adult sitting in the seat when tightened. Both the V-shaped rear straps and the single straps may slip down this way.
When you pit the carseats back in make sure you have something underneath it that will distribute the weight of the seat. If you lift the seat up the warning goes away.Update:
Took the car seats out, rebooted the car (twice! Via the power off button and via the scroll buttons), put the car seats back in.
The errors went away for a split second, but came back as soon as we started driving the car the next day. It's also intermittent in that it comes and goes during the same trip. What makes it really annoying is that the warning replaces whatever is in the left driver display and won't go away until you change the display, and the intermittent nature makes it come back.
Anyone else having any luck?
