Thats Okay. We have moved on to Natural Gas explosions anyway.One of the other mods must have decided to merge this with the induction stove topic.
Charcoal emits about 3x of the CO2 compared to propane/NG for the same task.
However, charcoal is made from wood, so all of its CO2 came from the atmosphere, while the propane is a fossil fuel. Seems like a toss-up.
Hopefully the CyberTruck will come equipped with a 15kw electric BBQ lol
Really? This is a very fallacious comparison. You’re comparing Roman ignorance of the effects of lead to our knowledge of CO and NO2 measurements? And our historic data where we can compare groups of people in household with gas appliances and without? As well as households with proper ventilati?And Romans thought that lead pipes for water were safe because they used them for a long time before the effects started to occur.
There are many more fires started from faulty electrical than from gas. In fact unintended cooking in general (regardless of the type of stove) is the biggest contributor. Then heating sources (mostly portable electrical heaters) are second. Fires from gas are not that high.Natural gas was the preferred method of lighting before Edison perfected the light bulb. We don't know if anyone was poisoned but there were a lot more fires back then that killed people. That is my main reason to want to get rid of it in my next home.
Actually boiling water at 8,000 ft is much quicker than at sea level as it doesn’t have to get as hot. So it boils sooner. But yes, boiling food sucks as it doesn’t get as hot (which is what I mentioned).Haha, Boiling water at Mamoth sucks compared to anywhere near sea level. Most clad cookware or inexpensive stainless cookware works fine. It just needs a little bit of iron content for the induced heat to work.
Moderator(s)This is my plan, brand new house so going to go with induction range and heat pump for heating and AC. That factor of 3 will be awesome for the heat pump, saving me 5-10 MW a year.
They're almost half of all fires. It's almost impossible to start a fire with an induction stove. So you would not only avoid fires caused by gas but also those caused by resistance electric.
This is exactly what I said. Cooking is the leading cause. Little of it has to do with using gas however. There are about equal numbers of cooking fires on electric and gas cooktops. It is the carelessness and neglect that are the main causes. Things such as grease fires (getting too hot regardless of heat source), or putting water in oil, ect. Few fires are a direct result of the gas flame igniting something.They're almost half of all fires. It's almost impossible to start a fire with an induction stove. So you would not only avoid fires caused by gas but also those caused by resistance electric.
Yes, gas cooktops will more likely lead to fires than induction, that of course is true
This is just flat out wrong. Not only would it be extremely hard to start a cooking fire with a resistance electric cooktop, it would be essentially impossible with induction. Perhaps only the old-school electric coil ranges would be of any risk, and even that would be minimal compared to an OPEN FLAME.
You have a habit of taking one sentence out of an entire paragraph and misleading others with what I stated in order to make it appear that I am wrong and your are correct. This is why every single time I had to reply back with "that is exactly what I said".This is just flat out wrong. Not only would it be extremely hard to start a cooking fire with a electric-resistance glass cooktop, it would be essentially impossible with induction. Perhaps only the old-school electric coil ranges would be of any risk, and even that would be minimal compared to an OPEN FLAME.
...Yes, gas cooktops will more likely lead to fires than induction, that of course is true
That is what I said. We are not in disagreement
Let's not forget to include the last sentence from my statement as well as all of the other important information that adds more clarity to the one sentence that you misinterpreted
For the stove directly, I completely agree. But like I stated in the post many fires are not directly a result of the flame or heating element ignition. They are from the food our cooking substance itself. So yes, it is less likely as carelessness, grease fires, etc. can still happen on induction. Of course the heating element itself in an induction won't start a fire like those of an electric cooktop or flameThere's a difference between 'less likely' and 'almost impossible'. Induction takes the risk of fire to ~0.
Overheated foods can get hot enough to catch fire even without an open flame or glowing heating element. So the few fires that do occur on induction stove tops are the result of the items themselves getting too hot. Many induction stoves have built in safety features that stop the cooking when the item gets too hot though. But I think we are more arguing over semantics between "not likely" and "nearly impossible"How? There is nothing associated with an induction stove that gets hot enough for ignition. It's the fire triangle. Heat, Fuel and Oxygen. With induction you simply don't have enough heat for ignition. What exactly do you think will start the fire?
