ptdusn
No, you can open them with them on and look at the date code on the front panelI take it I should throw the switch to off before opening up the boxes. Any reason to turn off the PWs first?
I'm still 1000% pissed that Vines has none of these disconnects.
Lucked out on the D switches. Lowest code is 1830.The affected recall units are these models with build codes 1401 through 1803 built in Mexico.
Still need to check the Eaton PV disconnect though as it also has a recall.
Do you have the reference or web link for this Disconnect Switch? Is it AC or DC rated? How many Amps?
It was a joke, it's not connected to anything.Do you have the reference or web link for this Disconnect Switch? Is it AC or DC rated? How many Amps?
Inspectors dont have the same rich sense of humor the rest of us do.You should leave it there when the inspector shows up and see if they notice.
Yup and it looks just like the 30A 600V one used on the PV pole in my yardThe 2018 recall on those Eaton units were for heavy duty 30 and 60A switches used in heavy commercial, utility and industrial applications per the article on their recall.
RECALL: Eaton heavy duty 30A and 60A safety switches pose potential safety issue - Electrical Business
July 6, 2018 — Eaton recently issued a recall for certain Eaton heavy duty 30A and 60A safety switches intended for use in heavy commercial, utility andwww.ebmag.com
Today I was commissioned! I have my PW on the app and have been distracted playing with them all day.
Some observations:
1. I need an internet hardline to the Powerwalls, otherwise they keep dropping if only on wifi. I have just 1-2 bars of wifi signal at my MSP
2. I love the app but it is pretty bare bones as far as data reporting.
3. There are so many good threads here that I now need to catch up on actually using the data from the powerwall. I also can play with my own powerwall system and experience what others are seeing.
4. Labels are being worked on today
Congrats man, it's been a long time coming lol. You've helped so many get their PWs, it's fitting you got yours hah.
Yeah @bmah needs to sell some kit to get his fancy API reporting to work without the person needing a CS degree to get it to work... some people like me are too stupid and posting on TMC too much to understand wtf a curl is.
Congrats.Today I was commissioned! I have my PW on the app and have been distracted playing with them all day.
Some observations:
Ok, inquiring minds want to know if your summary screen shows 100A for PANEL_MAXIMUM_CURRENT.Today I was commissioned! I have my PW on the app and have been distracted playing with them all day.
Some observations:
Good question, if only the TEG would let me into the commissioning wizard! The guys who normally commissioned it handled the tech the first time.Ok, inquiring minds want to know if your summary screen shows 100A for PANEL_MAXIMUM_CURRENT.
Did your commissioning team set it up on your home network? If so, you can use your router to see clients and associated IP addresses. You can get to your TEG via its IP address and go into installer mode that way.Good question, if only the TEG would let me into the commissioning wizard! The guys who normally commissioned it handled the tech the first time.
When I followed up with the procedure in the installation manual and tried it again myself, I get no response from http://teg-XXX so I am not sure what I am doing wrong. I downloaded Opera so the features of chrome weren't messing me up. I will try my laptop next time.
This seems like a silly problem but it's time for me to do the learning clearly.
