Part numbers for Door Panels and Trim (Wood / Aluminum) and prices:
1997295-00-A - G2H, DOOR TRIM ASY, FRONT RIGHT HAND - $275
1997294-00-A - G2H, DOOR TRIM ASY, FRONT LEFT HAND - $275
1803119-00-A - DOOR TRIM, WOOD DECOR, ASY, FRONT RIGHT HAND - $120
1803120-00-A - DOOR TRIM, WOOD DECOR, ASY, FRONT LEFT HAND - $120
1803117-00-A - DOOR TRIM, WHITE DECOR, ASY, FRONT RIGHT HAND - Don't know, probably $120
1803118-00-A - DOOR TRIM, WHITE DECOR, ASY, FRONT LEFT HAND - Don't know, probably $120
Panel comes with window switches, door open button, bolt cover, NVH Pad, and 2 clips for the tweeter.
Door Panel differences
- Flocked inside storage
- Has LED Ambient Light underneath the armrest, new connector, and slit to let out the light
- Picture below
- Hence the new part number for the 'Door Bolt Cover'
- Door NVH Pad
- Has a new seam going across the bottom 1/3 of the pad
- I prefer this one, it is like a box quilted comforter where it keeps the foam better distributed
- Door Trim Clips
- They are green color instead of black
- Put aside 1 hour to do this
- Small manufacturing improvements in the door panel itself
- LED Ambient Light
- My wiring harness doesn't have the connector for this light and I'm not about to buy a harness either
- The new light connector does appear in EPC in the wiring harness pic
- Door Trim Clips
- Same trim clip locations and locator points as the current door panel
- I put a video of how to take the clip apart
- There is a brand new set that comes w/the panel
- I did not use these ones because then I would have had to take apart each and every clip which wasn't fun so I reused the black clips
- Make sure the door panel has the male part of the clip and the door itself has the female part... otherwise not so fun
- Wood Door Trim looks great, but I wrapped mine since my dash was already wrapped
