have you considered a powerline network
You can extend your LAN via the mains cable they normally come pre-configured in pairs
You can add more if you wish.
Basically connect one to your router and nearest power outlet
plug in the second powerline adapter at convenient power outlet, connect a wireless AP to the second powerline adapter.
Power outlets you're using would need to be on the same phase if you can't get a connection between the powerline adapters try moving to another power outlet or if you have access to the electrical cabinets you should be able to find out
which Phase they are on
No dodgy WiFi extenders required, it's practically the same as having a network cable between the two points
Powerline networking: what you need to know | TechRadar
