Instrument cluster failing to start on 2015 Model S
David29
2,626
2,230
DEDHAM, MA
In the past week or so, i have had 3 instances in which I have gotten into the car to find the instrument cluster off, and it does not seem to start. With the Coronavirus restrictions, I have not been using the car every day, so that may be a factor. But I don't recall a case in the past when the instrument cluster would not start promptly after entering the car. The center screen, yes, it is normal for that to be dark initially and then boot up, if the car has been parked for a while.
I tried to reboot the instrument cluster at least one of those times, using the upper steering wheel switches, but nothing happened. But when I rebooted the center screen, then the instrument cluster did start. And it worked normally after that, for the rest of that trip (which may have included a short stop). So when it happened again, I went directly to rebooting the center screen.
Any similar experiences? Is this the sign of trouble? Or just something that happens when the car sits longer than usual...?
Only so much memory in our displays. Tech recommended that if it was slowing down to remove all the routes and chosen supercharger destinations that are stored forever. Simply swipe to the side and they will be deleted. Might be just enough to get you going.
Amazed at how many previous routes I had. Took 10 minutes to swipe each of them away.
Related to this - if you pair your phone with the car, and allow the car to access contacts, if you have lots of contacts downloaded to the car, this can slow down the MCU and also increase wear on the eMMC. I got this tip a few months back in the Watertown SC and immediately changed the settings to disable (or perhaps reduce - I don't recall specifics) the contact syncing to the car. It's been a little bit since then, but I seem to recall an immediate, but subtle, improvement in screen response after doing so.
I too have seen the IC black when I've gone to my '17 X the past few weeks. Like others, minimal drives since early March. It has woken up on it's own when I've stepped on the brake - I may have rebooted the MCU once to get it to work as well. I see this as a possible side effect of cars going into a deeper sleep, or perhaps related to recent firmware updates (i got 2020.8.1.1 March 20th, an upgrade from 2020.4.1).
Reactions: David29
... I see this as a possible side effect of cars going into a deeper sleep, or perhaps related to recent firmware updates (I got 2020.8.1.1 March 20th, an upgrade from 2020.4.1).
FWIW, I have been unable to install 2020.8.1.1, despite 4 or 5 attempts over the past 2 weeks or so. I followed the tips I read on another thread here about rebooting the MCU and then initiating the install from the car vs from the phone, to no avail.
I have 2020.8.1.1 and also 2015 car. @David29, same IC slow start as you.
With the shelter in place, I did change the power safe feature to on, but kept it "stay connected".
I assumed the slow IC start was linked to that setting, and the car was in sleep. I guess from your and the other's feedback it's not.
IC comes on eventually without any reboot, but need to wait a bit and maybe pushing the brake pedal does trigger it's wake up. Not driving much either, so don't do much troubleshooting either :)
Thanks for your post, always good to learn "I'm not alone". Also comforting as probably just a new software "feature"
Reactions: David29
Thanks. I may have been too impatient. I'll try again and wait longer if it happens.
I forget what my energy settings are (and my car is parked some distance away) but I think I have it set to "ON" as well as "always connected." I'll double-check that, too.
My IC has been dark when entering the car for about a month now. It wakes up without a reboot and then behaves normally. Concurrent with this the door handles do not present when approaching, and I must use the fob to enter the car. Also, my phone contacts and recent calls have vanished, and no amount of forgetting and re-pairing the phone has fixed it.
It seems likely reaching out to Tesla Service is in your future. Are you on an extended service plan or off warranty? Curious if remote troubleshooting of software installs is done at no charge or if they ding you for the time and an ESP deductible.
I have an appointment in mid-April for a mobile tech to fix a minor item, so when she/he comes, they can check on the software update and the IC booting if either or both of those remains an issue. I may push out the appointment a bit, depending on the status of the virus epidemic in my area.
I am on an ESP. In fact, the main reason I bought it is that the service center told me a few months ago that i needed a new MCU, to the tune of $2300, so I figured the ESA was a small additional price over the MCU cost. But as it turned out, the diagnosis was incorrect and they got me back on the road without replacing it.
I have not been in a hurry for the software update. It did not sound critical or exciting enough to fret about it.
In the meantime, i did take the advice to clear the Navigation system of most of my recent routes. I haven't tackled the phone contacts issue, yet.
Generally the SC will keep rewriting the emmc till there is no writes left. It's not uncommon to get a failing emmc to run just a bit longer. Hopefully your total failure will happen before your ESP expires. The newer firmwares should help emmc run much longer with the reduced writing.
just delete the phone and reboot......should. clear out the contacts so I have been told......the add the phone back ....... you dont have to add contacts back in until you get things straightened out
