Some manufacturer specification documents show all the test results, but as not all manufacturers show them it seems clear that they're available but do not have to be published.
For example, Jaguar's I-Pace brochure has the individual WLTP test results in the technical details section, it used to have it laid out by test cycle but the 2020 one has them as Low, Medium, High, Extra High and Combined (which is the figure you're talking about).
According to their small print, "
WLTP legislation dictates that where there is <5g CO2 variance between the lowest and highest figures, only the highest is declared.", so all EVs would only quote the highest figure for mileage since they're at 0g CO2 in all test conditions and manufacturers are not required to show you the other results.
I probably expressed myself badly, but the point is that Carwow are comparing their motorway driving test results with (at the very least) the Combined test results.
When they did this type of test and included an I-Pace they got 223 miles and said it got 76% of its quoted mileage (292 miles WLTP) - but that's rubbish. The WLTP figure for motorway driving has a maximum range of 244 miles, so it got to around 91% of the maximum WLTP range, but the results from the WLTP tests are actually 198-244 for that type of driving, meaning that you could also argue the car exceeded the WLTP figures for those driving conditions or at the very least it achieved the WLTP figures.
I'm happy for them to do tests like this, but I'm annoyed at them effectively misrepresenting the results as WLTP being wrong when it clearly isn't if you have the relevant data but how else do you level the playing field when not all manufacturers publish the figures you need?
So... I'm also annoyed that manufacturers are not required to disclose all test results to allow us to make informed choices based on the type of driving we expect to do or to make these tests more useful - I don't mind only using the highest figure from the combined results on advertising, but I would like to be able to see the other figures because at the moment the best I can do is assume I can get 75% of the advertised figure on long runs for any vehicle, which makes comparison difficult.
The Jag brochure is here and the results are on the third page from the end:
https://www.jaguar.com/Images/Jaguar-I-PACE-Brochure-1X5902110000BXXEN02P_tcm660-798742.pdf
