I know I've said this before, but what Tesla's built is amazing. To be honest, I wouldn't believe the charge/discharge figures if this wasn't Tesla's application.
Also, please link back to this post (Fred/electrek, I'm looking at you) if you use this in a media article/story/etc.
Credit goes to @Troy for predicting the tests were done with the Aero wheels (Sport wheels shave off almost 12% of the 3 LR's range at 50mph).
https://www3.epa.gov/otaq/datafiles/FOI_HTSLV00.0L13_APPIPT1.PDF
The motor is a 3‐phase AC internal permanent magnet motor utilizing a six‐pole, high‐frequency design with inverter‐controlled magnetic flux.
The battery is rated at 400V and is capable of delivering in excess of 1000 Amperes. The battery mass is less than 500 kg.
The dedicated High Power Connector (HPC) can be purchased separately from the vehicle and a certified electrician will confirm the capabilities of the residential supply circuit at the vehicle owner’s location. Confirmation of a satisfactory residential electrical Supply will lead to the installation of a hard‐wired HPC unit, this will expedite vehicle charging at the most efficient rate. The HPC can supply available current up to a maximum of 80 amps and incorporates electronic systems that communicate with the vehicle control systems to indicate the maximum available current so that the vehicle can determine the amount and rate of charge required.
Charging at rates lower than or equal to 32A can also be achieved via a mobile connector. The universal mobile connector is included as standard in the purchase of every Model 3 and is an individual cable that connects the vehicle to any available domestic power outlet and can deliver current to a maximum of 32 Amps. The Mobile Connector incorporates similar electronic circuitry as the HPC to communicate with the vehicle and manage the charging process.
The vehicle is also capable of accepting DC current up to 525A from an off‐board charger (Supercharger).
Model 3 comes with one on‐board charger is capable of a maximum of 48A on 208V or 240V outlets and 12A on 120V outlets.
An NFC card or phone app should be used to lock the car by scanning the card on the b‐pillar. There is no passive locking with NFC cards (car does not auto lock).
Note: Using an NFC card to lock/unlock will be equivalent to an active lock/unlock—i.e., clicking on the key fob to lock and double‐ clicking to unlock.
Do not store the battery pack in a manner that allows terminals to short circuit. Do not place near heating equipment, nor expose to direct sunlight for long periods. The battery pack should only be stored in approved packaging and stacked no more than two (2) packages high. To maintain service life, the battery pack should be stored at a state of charge (SOC) of 15 to 50%.
Range Test Results
Vehicle ID 3R217‐R00012
Transmission AV/1
ETW 4250 (4126 ‐4375)
RLHP 9.95 @ 50 MPH
City Range, miles 495.04
System AC, Wh/mile 180.6035876
System DC, Wh/mile 165.31
Vehicle DC, Wh/mile 158.11
Highway Range, miles 454.75
System AC, Wh/mile 196.6047279
System DC, Wh/mile 179.96
Vehicle DC, Wh/mile 172.12
Derating Factor 0.7
Five Cycle Range (mi) 334
MPGe 126
Tesla Desired Range (mi) 310
