Ok Ive just experimented doing what you and stopcrazy just said....Time Based Control
I’d start with setting an Off-peak period between 12-3, which should result in excess solar being stored by the battery until it’s full.
Setting a Peak period from 3pm to 12pm the next day should result in the powerwall discharging to cover house loads. Solar produced during that period will go to house loads first, back to the grid second if the powerwall is full.
In your rate plan set a fairly large difference between peak and off peak buy rates. If you want to prioritize your house loads at all times and minimize energy that goes back to the grid, set your sell price to zero.
I've set time based control
I've set off Peak period from 12 midday-3pm
I've set Peak from 3pm till 9 pm
I've set off peak from 9pm till 0700 (so it will discharge if necessary) off peak
I've set Peak again 0700 till midday (In an attempt to stop it charging during that time)
I've set grid charging "no" (I don't want the darn thing charging ever off the grid..(particularly when the sun is out pumping!)
It's 10.53 am here...
I reset the app (with the new settings above at around 10.00)... the robot sat quiet... all looked good for around 15-20 min... not charging.. not charging.. then darn it all.. KBOOM... it switched on started charging...
Gdarn it.. at 10.53...the darn Powerwall is pulling 3.9Kw and charging already... despite the above settings! see what I mean?
I don't want the battery to ever... ever... charge from 0700 until midday...
I want the powerwall to only start charging after midday! That is the best outcome for my particular set up and orientation.. in this part of the world...
Why is that too much to ask?!
How the heck do I stop it doing that unless I have direct control of when to "start the charging"...?
