I did and use them (well, 1 of them). They are great.Anyone buy the jack pads from AO? They seem a bit pricey at $100 for set of four, but look well made and functional.
I can confirm that the cheap chinese-made ones that you see on Amazon stink to high heaven. They use all kinds of nutty recycled plastics and rubber in Chinese "rubber" products. They smell AWFUL.If you want a set of (4) lift pads there are many choices available on Amazon. (Read the reviews carefully as some of the cheaper lift pads are known to give off an unpleasant odor for a period of time when new. Other lift pads have been reported as not fitting correctly and falling off the vehicle.)
I hear old hockey pucks work great.
You definitely don’t need to spend $100 on these things. Kinda defeats the point of doing the work your self to spend so much.
There is a Youtube that shows how to make your own lift pads using hockey pucks, grommets and machine screws. The cost of these components is the same or more that just buying a set of lift pads on Amazon.I can confirm that the cheap chinese-made ones that you see on Amazon stink to high heaven. They use all kinds of nutty recycled plastics and rubber in Chinese "rubber" products. They smell AWFUL.
Same thing for the "Tesmanian" floor mats. I had to take them out of my car after half a day because I was going to pass out from the smell. They tried to claim it's from some "cleaning process" but it's apparently well known that Chinese rubber products all suffer from the same issue. I've had them out in the driveway for a week and they still stink. Will probably return them.
May keep the pucks, but put them in a sealed plastic bag inside the case they came in.
Well, to be clear, hockey pucks don't have the little shaft that plugs into the holes at the Tesla jack points. So there's a possibility of slippage. These are not the same thing. Be careful what you post.
