Tesla says keep it plugged in. My service provider says run it down b/4 charging!
Now I'm confused! Thoughts?
What do you mean by your "service provider"? Electrical service, internet service? Why would someone in some other industry know better than Tesla how the battery packs in their cars are built and how they operate and what is best for them?Tesla says keep it plugged in. My service provider says run it down b/4 charging!
If you charge up at that supercharger close to you several times expect a call from Tesla.Are there negative effects of not charging the car nightly?
Would it be ok to charge 2-3 times a week? I live 10 minutes from a Supercharger and was thinking of just using that a few times a week.
I haven't heard if fewer charges would ruin or depreciate the battery faster, but perhaps it does if Tesla recommends keeping it plugged in.
Are there pros and cons with regards to battery health?
Glad to see another FL tesla fan up this earlyI wouldn't be surprised if supercharging 2-3 times per week would cause more battery deterioration than anything else you could do. Those things get hot.
If you're asking this question you have a bit to learn about Lithium Ion batteries.Why does everyone keep mentioning "90%" ? Is there no such thing as 100%?
I'll just add that this is really clear in the settings of the car. When you select to choose the charge limit, the display shows a section from 50% to 90% marked as "Daily". And then it has the 90% to 100% section marked as "Trips". I think it does still have the logic in the car that if you do actually charge to 100% for a few days in a row, it will display a warning to you that this is probably not good practice to use 100% all the time.If you're asking this question you have a bit to learn about Lithium Ion batteries.
I suggest searching a bit online for more details but the gist is this:
~90% charging nightly is what Tesla recommends. It give you 90% of your range for daily use and it allows the batteries to stay balanced and conditioned.
Charging to 100% gives you full range but should only be used when you expect to use/need full range. Such that you are leaving in the morning or the next day for a long trip beyond your normal daily in town usage.
Charging to 100% and keeping the batteries charged at that level without discharging any energy from them is not healthy for these type of batteries.
Ahhh - thx @pijjava34 for educating me!If you charge up at that supercharger close to you several times expect a call from Tesla.
They are not fond of local supercharging. They see and now promote supercharging as free for long distance travel.
Thx @NSXROX for this reminder.I wouldn't be surprised if supercharging 2-3 times per week would cause more battery deterioration than anything else you could do. Those things get hot.
@systemcrashed - If i'm only commuting 30 miles a day (round trip) is it still recommended to charge every night to 80-90%? Fortunately we have chargers at work as I was just planning to charge normally (won't use the superchargers nearby) every few days. Why does charging nightly to 90% keep the battery healthy, rather than just have the battery drain down to a certain threshold (i.e. 20% remaining?) I'm stingy about charging at home since I have chargers at work.Glad to see another FL tesla fan up this early
I agree that this would be the poorest battery management option you could choose. Plugging in every night and charging to 80-90% is optimal. Continuous high speed charging at high temps and full charging increases the batteries resistance over time, you could end up losing range over a shorter period than if you "slow charged" nightly when the battery was cooler. Besides, the overuse of a local Supercharger is bad Supercharger etiquette.![]()
Keeping the battery within the "middle 1/3" is where li-ion works best / lasts longest. Not good to stay below 20% or at 100% for an extended period of time. If you have chargers at work and use them daily you should have no issue (you are lucky to have that). Parking my car at home I would still plug it in just not schedule a charge (not sure you're aware you can do that) to avoid vampire drain as well. Assuming you work Mon-Fri, it will be charged to 80-90% on Friday when you get home, if there is 5-7% vampire drain, you would be ok. By plugging in at home and not scheduling a charge, or setting charge threshold to below 80% manually each Friday, you still won't be drawing much juice from home. Another idea would be to just use a 110v outlet adapter with your UMC to trickle charge when you're home.Ahhh - thx @pijjava34 for educating me!
Thank you all for the education and insights!
Do you wait until your iPhone or android phone battery is low before plugging it in? Of course not. So why all these questions about the Tesla? Just plug it in every night (or at work every day if that's where you plug in) and let the battery management system manage the battery.
If you read the owners manual you will find this advice in bold print.
1. YesI do however, every few months let my my die - down to 0%. Is this bad for a Teala? Would there ever be a reason to let my Tesla battery drain all the way down?
