DuplexDianne
How damaging is it to the battery if you go out of town and not use the car for several days? Expect there to be some drainage of the battery but definitely not advised to leave it plugged in the entire time you are away, right?I'll just add that this is really clear in the settings of the car. When you select to choose the charge limit, the display shows a section from 50% to 90% marked as "Daily". And then it has the 90% to 100% section marked as "Trips". I think it does still have the logic in the car that if you do actually charge to 100% for a few days in a row, it will display a warning to you that this is probably not good practice to use 100% all the time.
