Ok so now the Oct 19th announcement Q&A session is your source?
Because
upthread you wrote:
Again the redundant cameras are the main and narrow. It literally says it on tesla.com/autopilot
(I literally can't find this anywhere on the website.)
Anyway, Elon Musk
did not announce on Oct 19th which of the fwd cams will be active in EAP. What he actually said, was this:
Basically there will be two options for buying our cars, one is called Enhanced Autopilot which is kind of quite similar towards the Autopilot what we have been offering except it has redundant forward cameras and it has a left rear camera and a right rear camera as well as significantly improved Ultrasonic Sonar and much more computing power.
You seem to draw your conclusion from the word "redundant", and assume that
because of the FishEye cameras
shorter range, it
cannot be the "redundant" camera.
Well if that's the case - if that's all you base your conclusion on - then that's why we disagree. First of all: What's wrong with having the fisheye camera as a redundant camera? Why isn't the fisheye camera even
better as redundancy -
in urban environments? I'll argue that not only is it better, it is pretty much vital if EAP is supposed to deliver on "Smart Summon" and "Autosteer+". Because, if it's true that the Main camera has exactly the same optical properties as the AP1-camera (the same FOV and the same range), we already know that this isn't good enough for manuevering in tight, complex roads and "maneuvering around objects to come find you". The FOV is simply too narrow; there are too many blind spots. How is the
narrow, long range camera supposed to solve that problem? Using the Main and Narrow camera as the only fwd cams in EAP would in my opinion be unwise.
Secondly: You're probably putting too much into the word "redundant". Redundant does not mean - it
cannot mean - that one camera must be able to fill all of the Main camera's functions and properties, if the Main goes out. Because the three fwd cameras have different FOVs and different ranges. Sure, the FOV of the narrow camera is
more like the FOV of the main. But it's still not the same FOV. This means that you would get more blind spots using the narrow camera only, than using the main camera only. So what's "worse": Being backed up by the Fisheye camera or the Narrow camera? It depends on where you're driving, right?
Again: I'm
not claiming that I
know which one is the redundant camera. Not at all - that's why I'm so engaged in these discussions trying to find it out. What I'm doing, is trying to make an educated guess based on the sources that people in here provide. And right now, I'm not seeing that your sources (or assumptions) are more valid than anyone else's.
