Kalud
Sent PM. It looks like the cables you have are appropriately wired.
It is indeed appropriately wired. Its the OVMS Roadster cable and on the Model S its connected (by default) on the powertrain (CAN3)
This is really interesting.
How possible is it to map and decode CAN packs, in order to make a phone app with functionality similar to OBD2 apps like Torque? Meaning, seeing temperatures, wattages and other specs real-time? I'd be more than happy to contribute with android coding, if someone can help me with the hardware and the actual packet decoding.
The next idea would be to intercept and modify packets. I am thinking how cool would it be to plug a CAN 'thing' in between to connectors somewhere in the car, and:
1. Pick up and forward all packets, except
2. Intrepret and adjust the value of certain recognised packets before injecting them to the bus.
That way you could, for instance, adjust the height of the air suspension. I'd like a SLAMMED mode (for parking and low-speed showing off), and a slightly lower low.
@apacheguy and @msnow
There is pretty much no way (short of removing the connector) that Tesla could block access, I have actually seen the wiring of the diagnostic connector in relation to the center console and it's hardwired to all the buses once it comes out of the CID. Unlike ethernet, CAN was designed in the 80's when "cybersecurity" and "DEFCON" weren't even a topic at most automotive firms. In addition, with ethernet if you so much as plug in a connector to a computer you start to have a conversation and your presence is announced, this on top of the various ways that you can lockdown a wired network (which Tesla has decided to do). Not so with the CAN bus, you can almost always send and receive, though the various ECU's can be hardened against message injection, further there is no way to shutdown a device in listen only mode, meaning that while Tesla could make it difficult to inject messages, they can't talk away the ability to read what's going on (thats 95% of what most of us want to do anyway).
I am so tired of people assigning Tesla a "god" like omnipotence just because the car has an internet connection, JB and Elon will not rappel down from your ceiling to whisk you off to a detention facility if you decide to tinker with your car, nor should they. As many at the EFF would argue, you have the right to do what you want with property you paid for, especially something which is the second largest investment after your house.
msnow,
If you do "go there" on right to modify you should likely touch on Tesla's failure to publish modifications to the Linux core
