Would this latter idea also open up potential to use CAN bus message(s) for charging status...?
Charging status is on the power train CAN bus.
So we'd need to tap/log/filter two different CAN busses to get charging status, unless we can find something else on the body CAN bus like lighting up the charge port.
The charge port sits on the power train bus for sure. I don't think there are mirrors of that on the body bus.
Ok, I understand. What I can contribute is testing data from Europe. I'm only 1 hour away from the autobahn where I can do some testing at full throttle.
I love playing around with this stuff and learning about all possible details of the car so I'd like to buy a CAN bus logger that allows me to get a maximum of data to do so.
I'm sure I would be able to help some folks in Belgium and the Netherlands that have questions on their battery health and things like that.
From what I understand, right now the SavvyCAN is probably the easiest option but I need to find a way to get it shipped at a reasonable cost. The list price of $295 is fine but adding $190.79 for shipping + probably an additional European import tax + VAT on top looks a bit much in comparison with the list price.
Respect for the work you and others are doing to offer all of this to the community for rep points only!
wonder if the charge door status is on body bus then? ;-)
Not perfect, as not indicative of active charging status, though would be better than nothing...
So thanks to all of you, I have cell voltages:
But look at 65-72.
Thoughts?
But look at 65-72.
Thoughts?
Wow, looks like Module 12 is way out of balance with the rest of the pack.
But look at 65-72.
Thoughts?
But look at 65-72.
Thoughts?
What happens when you do another capture when the car is at a lower SoC?
Do all cells go down in voltage and are cell 65 to 72 still at a significantly higher V than the rest?
I don't think it was a parsing or algorithm issue. It occurred over multiple captures.
It was surprising to me that there was this much imbalance. However after about 10 miles this morning, I captured this:
I am using the updated conversion factors. Thanks wk057; and what a valuable asset your bench will be.
As I have never charged beyond about 60kWh (P85D), I thought this might be more info, but maybe not.
Looking forward to more discovery.
When I saw it at first, I was also thinking about variables that were not initialized properly and still had a previous value in them. Don't know it that is even possible with the software you are using to present the values.
Good to see that the issue got resolved. I also charge my car to a SoC of 70% if I don't need the range. But, I do a range charge at least once every 2 months to trigger the balancing. Can't wait to receive the CAN bus logger I ordered to see what my daily cycling between 30 and 70% SoC really does to the cells. I will finally be able to find out how fast they tend to go out of balance.
I have never paid much attention to rated range, I use % charge, and typically drive about 100 miles/wk.What is your rated range at 100%? Mileage?
BTW, what's the pinout on the FAKRA Ethernet connector? I'm getting my cables tomorrow (finally).
I spent some time looking for it this morning and I don't think so. Appears to only exist on CAN-3, it appears that the light and the door open/close are all on the same message.
