The reason R85 allows a power supply for the 30 minute continuous test, is simply because all current EVs would flatten their batteries at full power in under 30 minutes. It doesn't mean using an external power supply with a greater current capacity should be allowed IMHO.
As a clarification, ECE R85 allows an independent DC power supply for testing **both** NET POWER and the MAXIMUM 30 MINUTES POWER, as noted in Annex 6 of this regulation.
As for the reason for the specified duration for NET POWER and the MAXIMUM 30 MINUTES POWER, I do not believe it is due to limitations of the battery (this Regulation, after all, does not consider the battery limitations at all). The more likely reason, similar to sizing all motors, is driven by duty cycle, i.e. in this case application of the motor to the automotive propulsion system. The NET POWER is there to provide information about ability of car during short bursts of acceleration, while MAXIMUM 30 MINUTES POWER is intended to provide information on car's ability to sustain high speed driving.
The other examples of sizing motor to match expected duty is sizing motors for pumps and fans for continuous operation, as opposed to sizing motors for, say, elevators to sustain specific cycles of intermittent operation.
