What EVSE is it? It’s possible the flashing denotes an error code or you can pull error codes from it and go from there.Just ran for 1st time here in PHX. Charged 1 hour at 48amps then stopped and flashed red. Is the garage being over 100 degrees too hot or something else going on?
I'm in Florida with the same issue. When the garage is very hot, I point the ceiling shop fan at the charger and the overheat error does not occur. Additionally, I set the fan timer to coincide with estimated charge time..Just ran for 1st time here in PHX. Charged 1 hour at 48amps then stopped and flashed red. Is the garage being over 100 degrees too hot or something else going on?
Something most people are not even aware of. I believe it is 50 inch lbs.Check the torque on the terminal blocks where the power is fed into the EVSE. If they are loose they will be higher resistance and easily overheat (and be a fire hazard).
Given the same resistance, 48 amps will generate over twice as much heat as 32A .I believe it is something else. I’m in PHX and My garage is often over a 100 degrees in the summer and I have no issues. I charge at 32 Amps.
I suspect something is wrong. Does not sound normal even for a hot garage.Just ran for 1st time here in PHX. Charged 1 hour at 48amps then stopped and flashed red. Is the garage being over 100 degrees too hot or something else going on?
Appreciate all feedback. Electrician coming back this afternoonGiven the same resistance, 48 amps will generate over twice as much heat as 32A .
Power=current^2*resistance
48=1.5*32
1.5^2=2.25
@matty0505 is that on a 60Amp breaker?
100 plus degrees in my "hot" garage and I have no issues charging with 48A. Is yours Gen3 Tesla charger?nothing new. my UMC has the same issue in a hot garage (98F+)... plenty of youtube videos about it too. The UMC just gets hot without enough ventilation. Connectors and wires are good.
Just dial it down to 22A on hot summer days and it'll be fine. otherwise i charge at 32A which is the max.
whatever they included for free back in 2019 when you bought a car... using it with a NEMA 14-50 adapater... max charge rate is 32A100 plus degrees in my "hot" garage and I have no issues charging with 48A. Is yours Gen3 Tesla charger?
Let's be clear.Given the same resistance, 48 amps will generate over twice as much heat as 32A .
48=1.5*32
1.5^2=2.25
This the level 2 wall mount or mobile connector?nothing new. my UMC has the same issue in a hot garage (98F+)... plenty of youtube videos about it too. The UMC just gets hot without enough ventilation. Connectors and wires are good.
That’s a mobile charger. Pretty sure the OP is using a wall unit since he mentions 48 amps. It is important to point out these are different devices.nothing new. my UMC has the same issue in a hot garage (98F+)... plenty of youtube videos about it too. The UMC just gets hot without enough ventilation. Connectors and wires are good.
yes. sorry. the mobile charger is what i use and they are known to overheat quite easily in adverse conditions. not a big deal though as it will throttle automatically to 16A and only occurs when the garage is 95F+That’s a mobile charger. Pretty sure the OP is using a wall unit since he mentions 48 amps. It is important to point out these are different devices.
Yep. That'll do it. And lucky it got caught before the heat generated by the loose wire fried the breaker.Tech just finished. Secured Loose wire at breaker. Charged for 1.5 hours at 48 amp before I unplugged. Hopefully that was the issue and is now resolved
