Let's add some real numbers to get a sense of what LG is going to ship and how that compares to Tesla.
First, for reference, Tesla's current battery. It uses Panasonic cells, similar to the NCR18650BE, but with some normal parts removed. It uses nickel cobalt aluminum chemistry (NCA) and sports somewhere around 250-260 Wh/kg specific energy. Tesla puts 7100+ of these into a 85 kWh battery and the price point is somewhere around $280 / kWh retail consumer cost and somewhere around $220/kWh battery cost to Tesla and $160-180/kWh for the cells sourced from Panasonic's Osaka production plants. The resulting pack is about 1200 lbs, or 544 kg resulting a pack level density of 156 Wh/kg. The total retail cost of this battery as part of a new car is $23,800. Tesla allows about 5C max discharge and 1.7 C max charging (Supercharger for 60 kWh packs).
To use these cells to go to 120 kWh, assuming a linear addition of pack structure would then weigh 770 kg, or 1,700 pounds. That's a 500 lb increase for a 40% larger battery. It is also a volumetric increase which means you have to find somewhere to put the additional cells. Again, assuming linear cost increase, it would be $33,600 or a $9,800 price increase. Tesla obviously felt that going to a dual drive model was a better tradeoff than adding more cells of the current generation. Going to a bigger pack will increase range, but drivability will suffer, acceleration will suffer, and efficiency will suffer without the benefits of the second motor. Likely within the confines of the existing Model S design, additional battery structure will upset the center of gravity and the weight distribution as well as affect battery swap capability.
LG has been shipping cells for a number of EVs. They have roughly 6 GWh of cell production on tap but that capacity has been chronically under utilized. For more on that, see:
#3
They have signed deals with GM, Ford, Renault, Nissan, Volkswagen, Volvo, Hyundai-Kia, Daimler Mercedes, and Volvo for cells. As a result, this presentation by VW on the "Future Mobility" is of particular interest because it likely highlights LG Chem's product roadmap:
http://www.volkswagenag.com/content...entation+Barclays+London+Steiger+TOP+COPY.pdf
We are in the middle of the transition to NMC chemistry for non-Tesla automakers. The 2nd generation of NMC is likely to hit 220-230 Wh/kg specific energy at the cell level, which means roughly doubling the range of current non-Tesla vehicles. Note that is still lower than Tesla's 2012 specific energy levels. It is possible, or even likely that some manufacturers like Nissan will forgo liquid thermal management in order to achieve a simpler, less costly pack while also getting pack level specific energy that rivals or beats Tesla's 2012 benchmark of 156 Wh/kg. Also, NMC typically supports higher C rates than Tesla's NCA pack and higher cycle life. Hence the daily cycle version of Tesla's PowerWall uses NMC chemistry. The downside is lower specific energy and higher cost.
The Kia Soul EV already has 200 Wh/kg cells supplied by SK Innovation.
As you can see from page 18 of that VW presentation, we are about to see products from the first level of the "Outlook" section. That's the 2016 Nissan Leaf with a 30 kWh battery. We'll then get the next generation of cell going into Leaf v2 and the Bolt. This will enable the city type of products... the e-Golf, Leaf, i3, Bolt and so forth to have real usable range (150 miles of EPA range) that covers most commutes even in winter, even with cell degradation. It will propel the BEV market significantly forward. But it isn't a long range capable setup, as it is still behind Tesla's current chemistry.
Here is an Autoline interview where LG Chem's Prabhakar Patil discusses with a notable panel the future of batteries:
The Charge of the Battery Brigade - Autoline This Week 1833 - YouTube
As a result, LG can talk about 120 kWh batteries, but that means likely a battery pack weighing 925 kg or 2,000+ lbs with cooling and pack structure using chemistry they are shipping in 2016 or 2017.
We expect that Tesla will push new chemistry for the Model 3. Who knows, they may introduce that chemistry into a Model X or Model S well before Model 3 introduction.
