jomo25
But that is on opening, with the car thinking that the liftgate opening was blocked, yes?
That's different than the OP's case, I'd imagine, where presumably it's been sitting open for a while and just decides to close on its own.
That's the bug. The lift gate 'thinks' it is blocked so it begins to close. But in fact it wasn't blocked. (And mine was on level ground). The issue is the trunk hits the max, thinks its blocked and starts to shut on it s own, while beeping. That's why resetting the open point slightly lower than the max eliminates the issues. It doesn't 'bump' against the physical max and close.
I can't say for certain the OP was having this same issue. Bt it is the one I had. And others had. Which is why the support team knew of and advised this workaround til I next come in for other service.
