What will be involved in installing this? If pretty simple, I'm interested.
What does it look like in day light? Will it be on all the time or only at night?
Looks pretty much the same as the plain version. On close inspection the well-informed would see a difference but not John Q. Public. It's raised 9/32s" and the lighted area under the chrome T and arch are a kind of milky white. I'll take some photos tomorrow.I think he's (like me) wondering what the new T looks like in daylight (unlit)...Does it look pretty normal or is it an obviously modded T?
This version is not Plexi -- the T's are 3D printed with whatever material is used for that. Plastics to be sure but not Plexi. That helps with the light diffusion.
Rick
AMAZING results! The light is so much more even then before and looks so good.....!
Excited you are now tackling the rear "T" logo.... But I have a challenge for you
I think it would be SO COOL to have the embossed Tesla lettering on the rear chrome strip to light up at night so you can read "Tesla" in the dark. Of course, that would require cutting out the raised part of the lettering and putting some sort of thin flat lighting material (thin flat OLED white light or Electroluminescent Tape) to be placed behind the chrome strip.
EL Tape:
http://www.ebay.com/itm/like/121177931957?lpid=82
Do you think that is at all possible? And don't worry - I *know* I'm crazy!
Aaron
Great news that you have discovered a solution that doesn't require cutting the nose cone frame! I had backed out as a beta tester because I didn't want to cause permanent damage to the car. This is looking very promising.
Cool project Artsci! I know it's late in the game for this, but had you considered using Electroluminescent wire to provide the light? I've used this on a few projects, it runs very cool but not sure if it would provide the brightness you're looking for.
CooLight Electroluminescent Wire
Oops, I knew that. I guess I didn't have a good name for it since it's the raw material for the 3D printer.
- - - Updated - - -
Hi Aaron,
I just ordered that chrome strip from my local service center. I'll order a short length of EL tape (hopefully it's available in lengths less than a foot (which is all we need). Then I'll dremel out the letters and see if there's a neat way of passing a wire there (the back of the strip will tell me where the clips/holes are, etc).
I'll keep you all posted on progress. Maybe I should start a new thread once I get things going.
Edit: Does anyone know if EL tape can be cut basically anywhere along its length? It looks like the conductors run along its length which leads me to believe that it *is* possible...
EL material is basically a capacitor, so it's constructed as a "sandwich" of layers: the power conductors are the top and bottom layers (well, inside the protective layers), so it can usually be cut into arbitrary shapes. BUT...Does anyone know if EL tape can be cut basically anywhere along its length? It looks like the conductors run along its length which leads me to believe that it *is* possible...
- charges can accumulate at corners, so complex shapes won't be evenly bright
- the conductive layers have some resistance, so brightness can vary over large areas and long lengths (this is likely why there are wire conductors down the length of the tape)
- the material between the conductors is very sensitive to moisture, and will quickly degrade in the presence of water vapour; if you do cut it, be sure to seal the edge carefully to keep it waterproof
- changing the area of EL material will change its electrical characteristics; make sure the driver circuit can adjust appropriately
Here are some photos of the new lighted T installed on my car. The photos do not do it justice: the camera captures much more of the reflection on the V below the T than the eye actually notices.
We should have a kit available in about one month, when the 6 testers have finished installation and testing. Don't know price yet as the makers of the 3d T and arch have not yet billed me or even given me any indication of cost.
6 3D Ts and arches shipped to the 6 beta testers today. We should being seeing installation results early next week. In the meantime mine is running fine.
If all goes well I'm guessing the kits will be available in less than 30 days. After the testers have completed their installations and I have their feedback, I'll post detailed installation instructions so that everyone can make a judgment about whether he or she wants to do this as a DIY project or use an installer.
I'm super jealous! We don't need to get on 'the list' with you at this point if we want to get in on this right?
Any idea on cost?
