Looong car
Discussion in 'Model S' started by Zarwin, Mar 23, 2015.
Tags:
  1. Zarwin
    Zarwin Member
    Hillsborough, NC
    I don't have a whole lot of free space in my garage and always am extra careful to get the car backed in just right. About a foot clearance in front and two feet in the rear. No parking sensors so I just eyeball it and usually get it pretty close. I always walk around the front and double check before closing the door. Tonight I was in a hurry and had groceries in the back, walked straight to the back to unload and while unloading my wife was nice enough to close the garage door for me. Luckily I had backed in far enough, but by less than an inch. That was CLOSE!
  2. hadfiiw
    hadfiiw Member
    Cary, NC
    I am afraid of the same thing. A friend is going to bring his over and test it out before mine arrives.
  3. Zarwin
    Zarwin Member
    Hillsborough, NC
    Thanks. Didn't know this existed, at least not in an inexpensive form like this. I'll probably go this route or stick with my original plan to raise the safety sensor beam already there. That beam goes just slightly under the car so if I raised it up a few inches that should keep me from doing something stupid. Then again, the parking sensor would help me not back in too far. I've never backed in too far, but there is so little 'room' for error.
    Hell I'm so paranoid about that damn garage door that I cut the power off to it completely when I have the car partially backed in (which is rare but does happen on occasion). I'm afraid I'll accidentally close it somehow, or someone else in the house will instinctively close it going in the door in the garage. Hmm, raising the sensor will prevent this from happening also. Perhaps both options!
  4. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    This is what I would do. Moving the sensor covers 85% of potential problems, the laser another 10%. Not bad for $20 and some of your time.
  5. llavalle
    llavalle Member
    Somewhere around Montreal in Quebec, Canada
    3 feet of extra space is enormous! :)
    I have around 14inches total in my garage.. Even the new parking sensors can't help me as I need to park halfway in the "red STOP" zone ;)
  6. mmh
    mmh Member
    SLC
    I have the same problem in my garage, I used a more... low tech solution, duct tape, mans greatest invention.
  7. llavalle
    llavalle Member
    Yeah, my problem is that I have to almost always get the front in.
    I think I'll install a small bump on the floor. 100% effective.
  8. Cyclone
    Charlotte, NC
    mmh, I'd be terrified opening the driver door in your garage! Thankfully, my SUV can fit in both spaces with plenty of room, and it's only inches off in size to the Model S. Plenty of room for us.
  9. cgiGuy
    cgiGuy Active Member
    Sacramento, CA
    #10 cgiGuy, Mar 23, 2015
  10. MrClown
    MrClown Autosteer Beta Tester
    Denver
    I put one of these on each of the lower horizontal supports of the garage door that could ever contact the car:
    http://www.lowes.com/pd_21411-1410-S10XB/6_4294765361__?productId=1060001
    It is self-adhesive (sticks to both the top and bottom side of the support) and took about 5 minutes to apply each one plus some cleaning/prep. It's hard to tell from your picture if it would work on yours but it's cheap enough to try.
  11. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    Ha ha! I feel the same way. I have 18"...that's it, to fit my lovely girl in her boudoir. I glued a 2x2 board down to stop me at just the right point, which I back into and it works perfectly. I have only 1" of clearance to the door, so I always check. Works great, except when the car is out of the garage and I constantly trip over the damn thing. Haven't killed myself yet!
  12. megawhizz
    megawhizz Member
    Detroit, MI
    Same problem for me, a low(er) tech but very effective solution: http://amzn.to/1CLjwVu - works great even if the car is not completely straight, and if the backup camera is dirty with poor visibility
  13. Larry93428
    Larry93428 Member
    Cambria California, United States
    Zarwin, wow! That is close. There are some good suggestions above.
    I took a short string of Christmas lights, mounted vertically on the wall for a target. (Wish I had a photo.) I line the "T" of the rear hatch and back up until I hit a 2 X 10 that is on the deck. The lights are tied into the opener and come on when the door is open. It is a good target.
    ~Larry
  14. Rheazombi
    Rheazombi Member
    Boston
    This. I would definitely do this at least as a precautionary measure. Considering how many hundreds of times you park in your garage, if you mess up even 1% of the time/garage door closes, it would be nice to have a little bumper where it might have scratched the car.
  15. paulkva
    paulkva Member
    Falls Church, VA
    I bought two of the same item about 3 years ago for our previous cars. Simple, effective, and yes, low-tech. Only two downsides: (1) if the car isn't in the garage you can trip on it (as CHG-ON noted with the 2x2 board solution), and (2) you can't move it easily once it's set, so changing cars can be ... challenging. (I tried several different adhesives after the tape that came with it, and frankly I don't even remember what ended up working.)
    Whenever I have to make a change in the garage that would require me to move the AccuPark, I'll probably go for a laser-based solution.
  16. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    This works great for me -- a ball hanging from a string -- when it touches the windshield you stop...
  17. brucet999
    brucet999 Active Member
    Huntington Beach, CA
    #18 brucet999, Mar 23, 2015
    I use a black Magic Marker. Get the car parked far enough in to clear the garage door, open the car door, identify some landmark on the door sill, make a mark on the garage floor directly under that landmark, Draw a line about a foot long through your mark. Thereafter you simply drive in with door open until your landmark is over the line and you're done.
    No tripping hazard, no scaring the bejeebers out of you when you walk into a hanging tennis ball...and it's cheap.
  18. Kbsilver
    Kbsilver Member
    Central NJ
    I see the hanging tennis ball has already been suggested. In the past I have used a vertical black line on the wall (magic marker) that lines up with a reference inside the car. I've used the door lock handle in other cars, but as the Tesla does not have that sticking up, the edge of the door or side view mirror might work.
  19. RDoc
    RDoc S85D
    Boston North Shore
    I've got a bit more space than some of you guys, but am hoping that the auto-parking system will work to back the car into the garage such that the nose is very close to the closed door. We'll see how accurate the system is in a few months.
