Oh yea, they all do it. Did you come from an Audi, BMW or MB? Those cars are way quieter in the cabin. Having gaps between all the glass panels don't help either. Get that amazon silicone/rubber filler tube/band for the roof glass channel and you will see a tiny bit reduction in wind noise. Beyond that more insulation in the a pillar and/or adding more weather stripping and insulation in front doors can help as well.2022 LR. Is it normal to hear a pretty loud wind noise coming from the roof area while driving at around 70 mph?
Indeed, before M3 I had two BMWs and and two MBs which were exceptionally quiet at speed.Oh yea, they all do it. Did you come from an Audi, BMW or MB? Those cars are way quieter in the cabin. Having gaps between all the glass panels don't help either. Get that amazon silicone/rubber filler tube/band for the roof glass channel and you will see a tiny bit reduction in wind noise. Beyond that more insulation in the a pillar and/or adding more weather stripping and insulation in front doors can help as well.
It is disturbingly loud. My wife who drives Lexus always complains when she rides in M3 with meI'll clarify that my 2021 M3P is by no means silent at 70mph. Wind noise is present, and I've certainly been in cars with even less. But it's not offensively loud at all, in fact it's the quietest car I've owned, including quieter than my old Model S. It's really perfectly fine and relaxing at 70mph, and I can't imagine you would have made this post if your Model 3 was as quiet as mine.
Also as mentioned both Model 3's I test drove had the same perfectly fine wind noise levels. All three (2 demos + my car I purchased) were built early October 2021 in Fremont. That awful loud Model Y demo I tested was a 2021-Q3 car though, for what that's worth.
I have both a 2019 and 2021 and both are equally loud in my opinion. The 2021 may seem a bit quieter because of the front laminated glass. Since we don't know what is loud or normal to the OP, I raised the question to compare it to another car. The type of business I am in I get to drive many German cars and was a previous owner of BMWs and MBs the most immediate difference is the elevated wind noise level in Model 3's.@Motion122 No they don't all have that noise. Maybe older Model 3 did, but among 2021-2022 Model 3 and Y it seems to be somewhat hit-and-miss. I've experienced what the OP is talking about firsthand, and I can tell you my 2021 M3P does not have the issue, thankfully.
@berman2921 It's *not* normal, but unfortunately it does seem to be a recurring issue. A 2021 MYLR I tested had it real bad, exactly as you described. Neither the M3LR nor M3P I tested had it though, nor the M3P I bought. But others have reported it with new Model 3, for example:
https://teslamotorsclub.com/tmc/posts/6474469/
https://teslamotorsclub.com/tmc/posts/6506973/
And also new Model Y:
https://teslamotorsclub.com/tmc/posts/6508534/
Good luck getting Tesla service to acknowledge and fix it. I once came across a report here of someone who got service to replace their roof or windshield - I forget which - under warranty and that fixed it. That was a Model Y if I recall correctly.
both of my cars look just like that.I just noticed that in some places the roof rubber gasket was not installed perfectly and I can see the metal. Sorry for the car looking dirty in the pic
This solution will help for sure. Just measure the gap between your glass panels and get the appropriate width foam tapeIt is disturbingly loud. My wife who drives Lexus always complains when she rides in M3 with me
Thank you! Have you tried installing this tape on your car?This solution will help for sure. Just measure the gap between your glass panels and get the appropriate width foam tape
BLOSY Weather Stripping 3/8"W x 1/8"T, Foam Tape for Window Door, Adhesive Foam Insulation Tape Reduce Noise Dust Cold Air, 16FT Each x 3 Rolls, Black
I actually decided to use a 3” gloss black vinyl wrap tape to cover up the gaps. Now the glass is seamless.Thank you! Have you tried installing this tape on your car?
Here it is. Keep in mind I had to light up so that it can be seen. On a regular day outside, you wouldn’t even notice it. Oh, and the noise. What noise? I hear more road noise nowpics!
Door and windows wind noise have been fixed for 2022.I have a 22m3lr and most of the wind noise i get is from the doors and windows. I purchased a door seal kit that i will install this weekend. unfortunately this wont help my windows. Has anyone found a good solution for poor seals on the windows?
Night and day difference with the tape?Here it is. Keep in mind I had to light up so that it can be seen. On a regular day outside, you wouldn’t even notice it. Oh, and the noise. What noise? I hear more road noise now![]()
