I just lowered my long range RWD with TSportline springs and have some rear rake going on. The rears are about a half inch lower than the fronts, which really annoys me. I lowered an AWD with the TSportline springs, and the gaps were perfect front to back. I am wondering, does it take time for this to settle? Anyone else have an issue with the RWD springs from them?
It’s confusing what you’re trying to say. What is left and right side of fender? When ppl measure the hub to fender, they only measure the center of the wheel hub to the top of the fender. And mm’s are a more accurate unit than inches when you’re tying to compare the drop.Rear tire measures from center to left side of fender: 15" to right side of fender: 16" to top edge of fender: 14.50"
Front tire measures from center to left side of fender: 15" to right side of fender: 16" to top edge of fender: 15.25"
Thanks for your help! I know my post about height was confusing. Basically its a half inch higher on the front if I measure from the ground to the edge of the fender (ground is flat). Here are some picsView attachment 586346View attachment 586347
Hello all,
Is the general consensus that a Stealth Performance should be using the AWD kit and not the performance? I'm considering the Eibachs. Thanks.
PM me your ZIP code, maybe we can help find you a shop!Thanks and yes, they are blowing me off. They don’t recommend any shops up where I am which is frustrating. They are looking into it, so I really hope that they work with me in this, but so far it has not been promising.
,The eibachs are out of stock and I was considering Tsportline with their sale bringing the price it closer to the eibach but this issue and service does have me concerned about Tsportline. Hopefully they are able to help you with a solution.
If you are looking for springs, it seems to me Eibach and H&R have the least problems. Some UP springs have had noise issues although that may be solved now and obviously if you have an issue with TSportline this is an example of what you might expect.
