I spoke to UP about this, they are a big fan of the rear lsd as a way to prevent the ediff to kick on. They don’t actually mess with the electronics, they just give the car more mechanical grip to prevent the tc to come on
Other e-diff, like Mitsubishi Active Central Differential uses clutch packs and pumps. And Rear AYC on Evo was using 2 gears to speed up or slow down the right rear wheel to distribute torque electronically.
ACD uses 1 pump for both ACD and AYC.
AYC uses way more than 2 gears. It has organic clutch plates in 2 packs for left and right distribution, 3 concentric helical gear clusters with 2 additional centre helical gears, and it can distribute torque to left and right wheels. The later SAYC also uses a torque multiplier to increase the torque transfer capacity. This info isn't from Google BTW, I've been rebuilding these diffs along with many, many others for 15 years.
Do both one after another if you can.I think we're in danger of getting too bogged down in the technicalities of one diff vs. another. The ATB is a relatively low cost drop-in replacement which won't have any adverse affect on daily driving but should provide more mechanical grip when the car is driven hard. I had one on my last ICE car and although I'm not trying to compare that situation with this, I was happy with how it worked and the benefits I got from it, so I'm willing to give it a try in my P3D as an experiment.
Already decided I'm doing the rear initially and run it for a while before deciding if I want to do the front as well.Do both one after another if you can.
Evo X AYC drives right wheel only
Have you taken yours around Bedford yet?Hopefully we can meet up at a trackday and have a back to back comparison once done.
I disagree with #2. It’s actually less safe unless you know how to drive with one. Especially on the street because you rarely use it enough to get used to it. I put one on my bmw 335 that was tuned. It gave me sooo oversteer. I almost put it into a wall on the inside of a turn as that was more oversteer than I had ever experienced and it was completely unexpected. If it was safer you would see it a lot more on OEMs.Option 1 - don't tell her.
Option 2 - It's such a small cost to increase the safety of the car to protect you dear. With the extra traction, it could help our family avoid an accident...yada yada
I had an ATB on a 335 also. Even in sport+ mode you'd have to be driving pretty recklessly to put it into a wall. There's no point modifying any car with something like a LSD if your skill level isn't up to it.lol, it's simply an excuse to tell the wife so you can buy it. Chances are she wouldn't know the intricacies of how LSD works and if she actually does know, you won't even have to make up an excuse.
On a serious note, putting LSD on a Tesla would be quite different than LSD on a tuned 335. The Tesla's traction control is much better at managing traction.
..........a properly set-up plated diff is night and day better, there is no comparison. The majority of people I see on track are so far off the limits of their car and the track, the most value for going faster is driver training, not adding hardware. If you’re driving isn’t smooth, and you’re unsettling the car, brake application will be due to stability control, and an LSD won’t help. If you’re pro-level fast, and traction is the limiting factor (not stability control) I’m sure a helical LSD will help.
UP markets this for track use and states that most average daily drivers would not see any benefits. However they also state that it has a benefit in inclement weather such as snow and ice - and I assume that's not referring to racing in snow and ice. I wonder how this lsd would perform in winter driving conditions?
A helical diff will give you no benefit on snow and ice compared to the stock open diff. A helical diff can only transfer across the axle a multiplication of the torque that the wheel with least grip can use for traction. So zero traction means a multiplication of zero torque is transferred to the wheel with more grip, same as an open diff.
Also former Evo owner here- this not completely true. I live in snow country have probably drove an evo more than 40k miles on just snow. It is brilliant here, like no other vehicle I've ever driven. There is traction on snow and ice, especially with modern snow tires, and the helical and clutch pack lsd will happily deliver unbelievable acceleration both in a straight line and sideways. I don't own a Tesla, but this topic is why I'm lurking. I'm interested in m3 snow dynamics and this thread gives me hope.A helical diff will give you no benefit on snow and ice compared to the stock open diff. A helical diff can only transfer across the axle a multiplication of the torque that the wheel with least grip can use for traction. So zero traction means a multiplication of zero torque is transferred to the wheel with more grip, same as an open diff.
