JRP3
Hyperactive Member
I suggest looking at Glenn Doty's article previously linked, and the comments, on marginal load. There are good discussions on why EV's are marginal load, serviced by NG and coal.
That looks to be in state generated power. PA right next door has a large coal power base which they can send to NY.If I'm reading this correctly, NYS uses almost no coal for marginal power.
FWIW, economists consider all load in an hour to be marginal. There's nothing about order or historic operation. Prices on the grid paid by all load are set by the most costly generator. We don't assign the cheapest generation to "old load" and the more expensive generation to "incremental load." Everyone pays the clearing price. The same logically holds true for carbon. If we priced carbon, all loads in an hour, at a place, would pay the same marginal carbon tax.
......... solar power can be installed independent of EV's.
which is a huge logical fallacy (why aren't we looking at the emissions of the "marginal" gasoline, rather than the average?)
Canada’s tar sands, deposits of sand saturated with bitumen, contain twice the amount of carbon dioxide emitted by global oil use in our entire history. If we were to fully exploit this new oil source, and continue to burn our conventional oil, gas and coal supplies, concentrations of carbon dioxide in the atmosphere eventually would reach levels higher than in the Pliocene era, more than 2.5 million years ago, when sea level was at least 50 feet higher than it is now.
Air conditioners are marginal load because that's a spike of load during already heavy loads. Middle of the night loads just let whatever baseline stuff continue without reducing amounts. EVs flattening the demand curve actually reduce the margins, so therefore you are back at baseline loads.I suggest looking at Glenn Doty's article previously linked, and the comments, on marginal load. There are good discussions on why EV's are marginal load, serviced by NG and coal.
Glenn uses tar sands oil in his calculations.
That's an interesting piece of data I was not aware of.In some (most?) areas, if your solar panels generate more energy in a given year than you use, the utility will not pay for the surplus you generated. So the EV allows you to install more generation and transition your gasoline bill to solar, in addition to the electric bill. So in real life the EV can drive installation of more solar capacaty than a Prius.
If coal or NG plants don't throttle down as much at night because of the new load then emissions increase accordingly.Air conditioners are marginal load because that's a spike of load during already heavy loads. Middle of the night loads just let whatever baseline stuff continue without reducing amounts. EVs flattening the demand curve actually reduce the margins, so therefore you are back at baseline loads.
Well the argument being made is that EV's do increase emissions over a Prius type vehicle when calculated on a well to wheels basis.I've read a good portion of this thread and frankly can't tell why there is even a discussion. What difference does it make anyhow? Reducing carbon loads is the overall goal, isn't it? And until you can make an argument that an EV is using as much or more energy/carbon than an ICE then the origin of the electricity used for refining the fuel versus charging the battery seems to be so much noise.
Economics unknown, if it's not cost effective it won't be implemented.*) surplus renewable power can be put to good use in hybrid power plants. See enertrac hybrid power plant.
Transmission losses are small, and we still have the question about spinning reserves needed to be kept running to compensate for a drop in solar, or wind.**) In my opinion, rooftop solar can compensate overall electricity consumption by more than 100% because electrical losses in the distribution grid are reduced.
The need for spinning resources is minimal with proper wind/sun forecasting and distributed wind/solar generation. If reserves are still required to be "spinning" because they can't spin up/down fast enough, those plants should be upgraded to a modern CCGT plant with double the efficiency which are capable of very quickly and efficiently ramping up/down generation.Transmission losses are small, and we still have the question about spinning reserves needed to be kept running to compensate for a drop in solar, or wind.
Please give the calculations for amount of energy used to create 10 gallons of gasoline versus 85Kwh of electricity. Both should give about the same range, we could make it 5 gallons of gas if you would like to compare to a hypermiler.Well the argument being made is that EV's do increase emissions over a Prius type vehicle when calculated on a well to wheels basis.
This sentence: "Gasoline refined from the Athabasca tar sands project was scored at a carbon intensity of ~14 kg-CO2/gallon."
suggests (to me) that he is talking about the CO2 in the gasoline *after* refining. If you read the NYTimes article, it is obvious (to me) that he can't be including the CO2 amounts which are described there.
Previous studies have vastly underestimated the carbon footprint of the Canadian oil sands by not considering the industry's impact on peatlands, according to new research.
The study, “Oil sands mining and reclamation cause massiveloss of peatland and stored carbon,” finds that this destruction will release stored carbon equivalent to 42 to 173 million metric tons of carbon dioxide, “as much as 7-years worth of mining and upgrading emissions at 2010 production levels.
Claims by industry that they will “return the land we use – including reclaiming tailings ponds – to a sustainable landscape that is equal to or better than how we found it” (33) and that it “will be replanted with the same trees and plants and formed into habitat for the same species” (34) are clearly greenwashing.The postmining landscape will support >65% less peatland. One consequence of this transformation is a dramatic loss of carbon storage and sequestration potential, the cost of which has not been factored into land-use decisions. To fairly evaluate the costs and benefits of oil sands mining in Alberta, impacts on naturalc apital and ecosystem services must be rigorously assessed
10 gallons of gas at 33kwh equivalent per gallon is 330kwh. The entire petroleum chain from well to tank is about 80% efficient, so that means 20% is used to produce the final product, so the 10 gallons took 66kwh of energy, (not electricity). Now don't forget that the 85kwh's of electricity in a battery pack started out as a lot more energy than that using a generous 40% generating efficiency, (marginal power is probably lower), plus 93% transmission efficiency, a generous 90% charging efficiency, and not to mention the drilling/mining energy inputs, which I don't have the figures for. You have to apply equal criteria for all inputs when comparing gas to electricity.Please give the calculations for amount of energy used to create 10 gallons of gasoline versus 85Kwh of electricity.
From that article:
A new finding comes amid a debate about the carbon footprint of the oil sands generally. Emissions released from burning them still would be small compared with those from burning coal and natural gas
