JRP3
Hyperactive Member
Glenn Doty thinks the low NG prices are a temporary event from over production. NG pricing does seem to be volatile so he could be correct.
None, your water heater is in the base load - on average, when you turn your water heater on, someone, somewhere has just turned theirs off....When it comes on in the middle of the night what power source is increased to compensate? ...
Glenn addresses this study and points out it's not actually marginal emissions at all: Recent Analysis From The Union Of Concerned Scientist Is Garbage. - Glenn Doty - Seeking AlphaNot for California (where currently most of EVs are), according to this 2009 report: (Note these are marginal emissions)
ftp://ftp.dvrpc.org/dvrpc_misc/SMeg...nalElectricityforPHEVsandFuelCellEVs_2009.pdf
This means the best charging times are 2am - 4am.
Furthermore, a value of 568 g/kWh is a bit better than average grid at that time, and good even for NG.
This means in CA, night time charging is not coal level, it is NG level.
The model identifies the “marginal electricity mix” – the mix of power plants that is used to supply the incremental electricity demand from vehicles and fuels – and calculates greenhouse gas emissions from those plants.
So compare that to a fleet of EV's, all turning on around the same time over night, if we assume a large percentage of night time charging.
I think he objects to the inclusion of hydro power which is base load and load following, not marginal, and if used at night instead of being backed up it's not available during the day.He claims they don't understand the definition of "marginal", and he is wrong. This is even more obvious when you look at all the graphs of a previous incarnation of that study. They examine in detail which power plants are used to address incremental load, additional load. They go as far as examining this for different times in the day, and different months. That is the meaning of the table I posted: It describes the CO2 emission specifically of that power which is used to address marginal load.
Except at night, when there is excess coal capacity. Why power up a more expensive NG plant if there is cheaper coal capacity available?And you haven't answered this yet, which may be a crucial point:
If otherwise NG has a higher cost, then that should mean that NG would be used for marginal power, not coal.
How does extra demand "replace" power? Coal and NG plants reduce output at night, increased demand means they reduce output less.Not if EVs are charged during the the period of lowest consumption in the night. Then they smooth out the demand curve, and replace power that is turned off.
Again, future projections, which I do expect to happen, but not currently relevant. Until it's proven cost effective it's just speculation.When using Vehicle-to-Grid communication, they can increase the continuity of demand, and reduce the need for dispatchable power generation.
"The entire "marginal impact" study is based on the relative input of hydropower in some time frames verses others"
Adding demand in CA-S typically increases marginal emissions rates, because NGCT plants often operate on the margin there.
A fleet of EV's charging at night is a large load on the grid that will increase emissions. Yes it may even out the day/night ratio somewhat, but emissions will increase. Unlike MPT's water heater scenario there probably won't be a bunch of EV's turning on and off over night to compensate and average out, they'll all come on around the same time and all shut off around the same time.That was a typo, it should have said "power consumption", instead of "power". The point is that less dispatchable power is needed, which is more or less the point MPT was making: that things may "average" out.
Because I can't tell the future? It's going to cost a lot to implement, and from what some people in the industry say the current grid technology is based in the 1960's. Being able to "throttle" a fleet of plugged in EV's could be a game changer, but we aren't there by a long shot.If you expect it to happen, why do you call it "speculation"? It's not a major point in any case, I just mentioned it because I also expect it to happen.
I guess I don't understand what is being argued. Should we not be getting EVs then? While in the short term people buying EVs and charging at night my increase emissions, so would new subdivisions, new factories would all increase emissions...etc
ZZZZZZZZZZZZZzzzzzzzzzzzzzzzzzz
Last I knew LA imported a huge amount of coal power from out of state, something around 40% of usage. So if you are part of the LA grid you may very well be charging from coal. Saying there are no coal plants in CA doesn't provide the whole picture. That's my main point of this whole exercise, that we have solid factual data to use.To make the point clearer: There are no coal-fired units in California, and the last one in Oregon is closing soon. So there's no doubt that EVs on the US west coast are less polluting than ICEs.
You are mixing two things. Installation order and operation order. In this example you are making the assumption that what matters is what is turned on first (your water heater was turned on at a time when all the nuclear capacity was already assigned), not what is installed first. There's a major difference. To make it clear, here's an illustration.Sure, at some point in time a certain amount of charging EV's probably will be covered by an expanded base load power supply. With enough EV's on the road there will always be an EV charging somewhere at some time so a certain portion of the fleet load will be considered base load. But consider this, I have an electric hot water heater on a night time use timer. It's probably 10 years old, so I guess we can consider it as an established load on the grid. When it comes on in the middle of the night what power source is increased to compensate? Obviously not solar, unless the wind happens to pick up when it turns on it's not wind, if it's hydro then that hydro can not be backed up for daytime use when it's more valuable, so it's probably going to be NG or coal.
