Could switching gears before the car is at a complete stop cause any damage? For example, if backing out of a spot, then putting the car in DRIVE while still coasting backwards.
No, because this car doesn't have transmission gears or a clutch. Forward and Reverse are the same thing; it's just a question of which way you tell the electric motor to spin.
If you have the car in Roll and you're on a steep incline, you can bring it to a stop by pressing on the accelerator lightly. You can also allow the car to roll back slowing while pressing the accelerator and see the car picking up charge from the regen.
If you are on a steep decline, you can put the car in reverse (which simply directs the motor the other way) and again use the accelerator to stop. And, if you allow it to roll forwards, you can regen. That's right, rolling forward with the car in reverse, you press the accelerator to cause regenerative braking. It's kinda fun. (Only do this safely, kids.)
Since there are no gears unmeshing/meshing, there's no danger change direction. HOWEVER, if you're flipping between Forward and Reverse to use the accelerator to to stop the car, you DO run the risk of accidentally accelerating when you intend to stop. You need to be certain that the direction change takes effect before you press the pedal! Over 5 mph, it WILL NOT switch, so if you hit the stalk thinking you've switched, you may hit the accelerator and then unintentionally accelerate. A couple times I'd hit the stalk and had to abort to the brake pedal at the last instant when I realize the car isn't switching directions and it's a bit of a panic.
My conclusion is that this “feature”, which obviously is the cause of so much controversy, with all the clicks, surges and other negative characteristics, is definitely not for me. I will reconsider if/when I read that improvements have been implemented and more positively accepted.
1. I disagree. I've tried the new driving mode, and decided it's quite excellent. There were a few situations where I needed to adjust, but they're all quite doable. Overall, I think it's a huge boon, and it became my standard mode the first time I turned it on.
2. The improvements will never be "more positively accepted." People are just being resistant to change, and this is a change. Those of us who are willing to adjust get the benefit... others, coming into it for the first time, will also get the benefit. But those who got used to the car as it was and don't cope well with change will just complain, and that won't change.
my windshield wipers turned on by themselves. It was bizarre. It wasn’t even raining today so absolutely no moisture on or near windshield.
It's not about moisture. My understanding is that it's based on what the camera sees on the glass - so all that matters is whether there's anything on the glass right in front of the camera, or else a glare hitting that spot.
I'm an early '54 model myself and have more precise control with Hold then ever before. Every time I go to reverse I try to understand why some folks say the control feels odd. So far I got nothing..........
Hey, old-timer. I think the problem is that these whipper-snappers have only driven one or two different cars in their lifetimes - and most of them like-new. They're not used to adjusting to significantly different pedal response in the accelerator, the brake, and the clutch when switching between cars. You and I have probably gone through lots of different cars... every time I get into a different car, it's like driving a whole new car.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I just expect a software change to require the same adjustment
in me.
If Tesla can increase power (decrease range) through software they can toggle it to favor efficiency or power.
@diplomat33 does this make sense to you?
Believe it or not, I had a lot of physics. I know the difference between power and energy or, kinetic vs potential energy. I said power. I have no clue where you got energy from. What I said was in order to give us 5% more power out of the same plant, something had to give
The key here is that nothing has to get worse for the car to give us 5% more kinetic power out of the same inverters/motors. If they were able to tune the system to be more efficient, the same amount of electric power from the battery will yield more mechanical power from the motor. This is why this update gives us both more power and more range: it's based on increased efficiency.
So you don't need to hit the pedal as hard to get the same amount of pickup as before. However, if you DO hit the pedal as hard as before, don't expect to save anything. If you let up on the pedal to get the same pickup as before, you can expect a slight savings.
It'll be hard to detect, though, because it's a small difference (5%) and because the weather's getting colder (battery efficiency drops in the cold, and because our batteries are so big, that's a lot of thermal mass that gets cold after a long night - it can take quite a bit of driving in the morning before it warms up to peak efficiency.)
But doesn't chill mode already do what you are suggesting? It suppresses power and results in better range?
Close, but not quite. Chill mode re-maps pedal response so that it's easier for you, as a driver, to avoid using as much acceleration. So it's less like "supressing" power, and more like getting you to ask for less power in the first place.
But yes, chill mode makes it easier to be energy-efficient.
Having said that, I am certainly not opposed to Tesla adding an "extend range" option via OTA update.
I think a "high-efficiency" or "hypermiling" mode would be great, especially as an autopilot option. I suspect there are acceleration rates that are more energy-efficient, and deceleration rates that capture more energy. If they're not wildly out of line with regular traffic, i'd love to be able to engage those.
Except when reversing down a steep drive.. then you feel like you are fighting the car.
I know what you mean; the first time, the impulsive response is that the car is "getting stuck" instead of rolling down the hill. Normally, you'd expect to hit the brake, and to make the car "go" by letting off the brake. Instead, the car stops itself, and you make the car "go" by lightly hitting the accelerator, telling the car, "it's OK, it's OK, keep going..."
I got used to it almost immediately. In the new mode, the car knows you want to stand still when your foot is off the accelerator. Regardless how steep the incline, the car will stand still until you press the accelerator - and when you do press the accelerator lightly, it will just inch forward, rather than suddenly rushing down the hill as it would in Roll mode.
Frankly, the new mode is wonderful and much safer, I think, as long as you can stop acting as if the car is going to suddenly roll downhill. It's not.
This is
so much better than learning to clutch into first gear after a red light on a steep incline, especially the first time you're allowed to drive your father-in-law's BMW, which has a ridiculously small slip zone compared to your Honda. But I digress.
By the way, anyone hearing a small but discernible click when the car hits "0" and the hold indicator comes on?
I'm fairly sure everyone has the click. For most of us, it's so quiet that we rarely notice. Some people have a louder one, or else are very sensitive to it.
I think I've heard that. Isn't it mechanically going into park?
No, it's just the electronic actuator beginning to engage the brake. You can easily feel this with a little playing:
In a safe place, on a flat area, with the car in the new mode:
1. Put your right foot on the accelerator, and your left foot UNDER the brake, lifting it slightly.
2. Press the accelerator enough to bring the car up to 2 or 3 mph, and then let go.
3. You'll feel the car slow down via electric motor control until it stops.
4. Then you'll see the (Hold) engage on the screen.
5. Then you'll hear the click.
6. Then you'll feel the brake pedal move down, so that the brakes are holding the car still instead of the motor.
The click is at the beginning of the brake pedal movement (possibly an instant before.)
